Intercon question
Posted: Fri Jul 11, 2025 1:21 pm
by NeilS
Hi,
Generally I have found Intercon very good but I am finding that the contour feature in .dxf import is well.......just a bit rubbish! all the other dxf import tools work well and I have used them quite a bit. I need to cut an outside profile 40mm deep but the contour doesn't support multiple passes so there has to be lots of hand coding to add sensible lead ins and exits and deal with the depths. Is there an easier way that I am missing?
DXF and pdf attached for referance.
Best regards,
Neil
Re: Intercon question
Posted: Fri Jul 11, 2025 2:32 pm
by cncsnw
No.
You have to edit in your own lead-in and lead-out, and then use Depth Repeat.
