Acorn board new project
Posted: Fri Jul 11, 2025 9:00 am
I am done with the controller mechanical (housing) aspects of things. I am starting the wiring. The Acorn controller will be connected to Gecko gr214v drivers. From the various posts I read, I have the options of going to the db25 or the screw type "H" connectors. From the looks of it i could go both ways. Where I get confused is the "pull-up"/open PNP/5V push / pull logic". Motors voltage will be 48 Volts.
How does the limit switches logic operates? Beeing in series the contoller cannot know which axis is tripped. (Just curious)
Also, I noticed there is a cold joint/corrosion on the back of the board where the Seed risers are connected. I have not yet powered the board but I have a concern it might affect the contoller's interface. Please advise
While registering i was asked for the board serial number. Cannot find it nowhere.
