Lathe Fusion Post Request
Posted: Wed Jul 02, 2025 9:25 am
by fusion
Would it be possible to add a check box to the community Fusion post processor that adds spindle speed variation and feedrate variation?
Thanks!
Mike
Re: Lathe Fusion Post Request
Posted: Wed Jul 02, 2025 11:06 am
by vw_chuck
Where is this community Fusion PP???
Posted: Wed Jul 02, 2025 11:08 am
by suntravel
Yes I could do this, but....
No I will not do this
Simply because as a value in the PP it would be on for the whole time for all tools.
The better way to do is with Pass through manual NC
Then save as a template in your cloud and you could drag and drop it where you want
Example here only for profile roughing.
You can also make different templates with different parameters for SSV and FRV using G10
Posted: Wed Jul 02, 2025 11:15 am
by suntravel
vw_chuck wrote: ↑Wed Jul 02, 2025 11:06 am
here:
viewtopic.php?t=11259
Posted: Wed Jul 02, 2025 2:20 pm
by fusion
Uwe,
Thank you for that idea. I was editing the files in a text editor.
What does this mean, "You can also make different templates with different parameters for SSV and FRV using G10" ? I thought the parameters were only set in the wizard.
Mike
Posted: Wed Jul 02, 2025 2:47 pm
by suntravel
G10 P1982 R0.1
G10 P1983 R100
M94 /70
Will turn on SSV with +-100rpm / 0.1s
You can write parameters with G10
The wizard is just a tool for user convenient to set up CNC12 / PLC / macros / parameters
Everything the wizard is doing can be done in another way too.
Posted: Wed Jul 02, 2025 2:53 pm
by fusion
Thank you!
Posted: Wed Jul 02, 2025 3:27 pm
by fusion
I've tried this, but when I post the file, the M codes are not in the file. What do I need to set to have them post to the file?
It says you have to modify the post to allow this function.
https://www.autodesk.com/support/techni ... r-HSM.html
https://www.autodesk.com/support/techni ... rking.html
I tried following their instructions, but the "onManualNC" section of the post was not there. So I didn't know how to proceed.
Posted: Wed Jul 02, 2025 4:29 pm
by suntravel
This function was removed from autodesk
Now back on track again
New V3 PP is here:
viewtopic.php?p=101826#p101826
Posted: Thu Jul 03, 2025 9:05 am
by fusion
Thank you very much!!!
