AI suggestions for writing G-code
I recently started writing a few small g-code routines. For fun, I told CHATGPT what I wanted to do, and it wrote the code perfectly. I found it extremely helpful, as I knew what commands I wanted to use, but it helped with the syntax and added notes for each line in a fraction of time it would take me to do the same. I believe, it is helping me learn g-code faster than without it.
Just curious, is anyone else using AI to write code? Is there an even better mouse trap than CHATGPT?
For fun, I attached the simple routines that took about 3 minutes to create.
Thanks... Richard
Thanks... Richard
- Trim Top CHAT Numbers.txt
- (325 Bytes) Downloaded 71 times
- Trim Right CHAT Numbers.txt
- (323 Bytes) Downloaded 121 times
- Trim Front CHAT Numbers.txt
- (319 Bytes) Downloaded 61 times
Re: AI suggestions for writing G-code
I can write this in under a minute, or for a full functional code with spindle, tool change and Z moves Iet Intercon dot it
I use AI for Phyton and Java Script, but for g-gode specific to CNC12 or other systems I prefer to use my head.
To my surprise, CHATGPT appears to be able to write g-code specific to CNC12. Here is an example of where I wanted add the use of variables to the previous code:
Great! Below is a fully working example of a parameterized “Trim Top” routine for Centroid CNC12, using:
• A main G-code file that calls a macro (M101 Q7.85)
• A macro file (mfunc101.mac) that does the actual trimming using the Q value
________________________________________
1. Main G-code File (calls macro)
You can name this file something like trim_top.cnc:
gcode
CopyEdit
; TRIM TOP using macro with variable distance
M101 Q7.85 ; Call trim macro, passing 7.85 as trim distance
This sends Q7.85 (the trim distance) to macro M101.
2. Macro File: mfunc101.mac
Place this file in the CNC12 macro folder (usually c:\cncm\mill\mfunc or similar for milling machines).
Filename: mfunc101.mac
gcode
CopyEdit
; mfunc101.mac - Trim Top Edge using Q as trim distance
G91 ; Relative positioning
G1 X[-#1] F30 ; Move left by trim distance
G1 Z0.2 F20 ; Raise Z
G1 X[#1] F120 ; Move right by trim distance
G1 Z-0.2 F20 ; Lower Z
G90 ; Return to absolute positioning
#1 is the system variable that receives the Q value from the G-code call.
🛠 How to Use It
1. Save the macro as mfunc101.mac in your Centroid macro directory.
2. Call M101 Qxxx in any G-code file with the trim distance you want (e.g., Q7.85).
3. The macro handles all the relative motion based on the passed-in value.
Why This Works:
Centroid CNC12 doesn't allow math expressions like X[#100] in the G-code file, but it does support macros with passed parameters, so this setup is the clean, maintainable way to parameterize distances.
Inspiring!
gcode
CopyEdit
gcode
CopyEdit
🛠 How to Use It
Inspiring!
IMHO this is bullshitRJS100 wrote: ↑Sun Jun 29, 2025 1:33 pm To my surprise, CHATGPT appears to be able to write g-code specific to CNC12. Here is an example of where I wanted add the use of variables to the previous code:
Why This Works:
Inspiring!
X[#100]
is not a math expression but x with a value of #100 user variable
#100 = 1
X[#100]
will be the same like X 1
Read and understand chapter 8 in the manual and you will outsmart ChatGPT in no time
Let us know how that custom M101 macro and Q parameter work out for you....
Hi KI
here is a link to my cncm folder of my 6 axis mill: ....
pls make some g code to grind drills with 4 facets so that I have only to touch off the drill in Z
As you can see, I would use the D75mm Diamond wheel in T04
If this would work, I would be impressed
And I have not asked for thinning out the tip
By the way, the best AI tool for Centroid I know is Paper Tools with Camera support....
Hello Uwe,
You mentioned that reading chapter 8 of the manual for programming g-code. From what I can see, chapter 8 is on digitizing. Did you mean chapter 12 for g-code?
Richard
Richard
ups. 8 is CNC Programm Codes in the lathe Manual, it is 11 in the mill manual.
Next two chapters G-codes and M-functions are also important to learn Centroid g code
