Hey guys,
i have a problem setting up the scales on my machine viewtopic.php?t=11657
I had to invert Axis 1 (Z), so i entered -1000steps/mm instead of 1000.
Slowly jogging with the WMPG handwheel works, also for long distances, but when using the jog+/jog- buttons (VCP, WMPG, Keyboard, no matter where) the axis faults after maybe 50-100mm travel with "position error"
I chatted with Uwe, and he told me to enter 0,5-0,8 to the value "max-Diff" in the scales setup (most right value).
So i entered 0,5 there, hit enter, then save, exited scales-menu and double-checked, if the value has been saved. It has been saved, value is 0,5.
I exited CNC12, restarted CNC12, but still the same problem, axis goes to fault when jogging by keyboard/going fast. So i wanted to lift up the max-diff-value to 0,8. I entered setup, machine, scales, and the entry there is now 0,1 again?!?
I re-checked that behaviour multiple times.
Set diff-max to 0,5, saved, exited CNC12, restarted CNC12, and the value is back to default 0,1?
Report attached.
The scales themselves do work, when i push/pull on the slides, the last digit is changing slightly and the motor corrects that.
What am i doing wrong?
Thank you,
Marc
Scale Setup not saving values?
- report_0008DC111213-1113240204_2025-06-27_21-19-18.zip
- (995.18 KiB) Downloaded 37 times
German-speaking, so please be patient with my english-skills
Re: Scale Setup not saving values?
You are using 5.28
Get the latest 5.30
Do a fresh install, not restoring report....
The settings are stored here:
Get the latest 5.30
P571 = 0.50000 - Axis 1 Maximum Scale Difference (in, mm, or deg)
P572 = 0.20000 - Axis 2 Maximum Scale Difference (in, mm, or deg)
P573 = 0.10000 - Axis 3 Maximum Scale Difference (in, mm, or deg)
P574 = 0.10000 - Axis 4 Maximum Scale Difference (in, mm, or deg)
P575 = 0.10000 - Axis 5 Maximum Scale Difference (in, mm, or deg)
P576 = 0.10000 - Axis 6 Maximum Scale Difference (in, mm, or deg)
P577 = 0.10000 - Axis 7 Maximum Scale Difference (in, mm, or deg)
P578 = 0.10000 - Axis 8 Maximum Scale Difference (in, mm, or deg)
1 user liked this post
I just updated to 5.3 and yes, THIS version seems to save that values correctly
But at first, on 0,5mm max diff, my axes were swinging extremely after every move! We are talking about approx. 1/10 turn back and forth! (2mm pitch)
So i set it to 0,1mm again to start finding a sweet-spot from there on, but with 5.3, now i can also jog faster on 0,1mm max diff without faulting, and there is also no swinging anymore.
But as this the first time for me installing servos, i will have to learn to fine-tune the axes first, too. I just made that one-click-tuning now. Which, btw, seems to give good results, no see- or audible swing, no strange sounds, no vibration. But it can't be THAT easy, right?
Even if it's Leadshine...^^
If anyone knows some documentation, video, or any other resource, where tuning of a servo-motor on a cnc-machine is shown, i'd be happy about some links or info on it
I mean the basics regarding tuning here, e.g. what values to monitor in the scope, what deviation-results to achieve and so on.
Best regards,
Marc
Best regards,
Marc
First step is to tune your servos as stiff and fast as possible.
Second step is to tune the scale feedback loop in CNC12 for minimum oscillation
I prefer to use P#620-635 to tune the scale feedback...
P620 = 0.01200 - Axis 1 Scale Proportional Constant
P621 = 0.01200 - Axis 2 Scale Proportional Constant
P622 = 0.00500 - Axis 3 Scale Proportional Constant
P623 = 0.02000 - Axis 4 Scale Proportional Constant
P624 = 0.02000 - Axis 5 Scale Proportional Constant
P625 = 0.00000 - Axis 6 Scale Proportional Constant
P626 = 0.00000 - Axis 7 Scale Proportional Constant
P627 = 0.00000 - Axis 8 Scale Proportional Constant
P628 = 2.00000 - Axis 1 Scale Max Correction Velocity (encoder counts / interrupt)
P629 = 2.00000 - Axis 2 Scale Max Correction Velocity (encoder counts / interrupt)
P630 = 2.00000 - Axis 3 Scale Max Correction Velocity (encoder counts / interrupt)
P631 = 2.00000 - Axis 4 Scale Max Correction Velocity (encoder counts / interrupt)
P632 = 2.00000 - Axis 5 Scale Max Correction Velocity (encoder counts / interrupt)
P633 = 0.00000 - Axis 6 Scale Max Correction Velocity (encoder counts / interrupt)
P634 = 0.00000 - Axis 7 Scale Max Correction Velocity (encoder counts / interrupt)
P635 = 0.00000 - Axis 8 Scale Max Correction Velocity (encoder counts / interrupt)
