Page 1 of 2
Servo motor temperature
Posted: Wed Jun 25, 2025 3:56 am
by Cncsteve
Hello,
I have recently installed a stepperonline a6 servo motor and driver, everything works 0-10v etc but the motor is getting super hot, I’m thinking voltage or torque settings? Could anyone point me in the right dire As to what else I could check?
Many thanks.
Re: Servo motor temperature
Posted: Wed Jun 25, 2025 4:10 am
by suntravel
Do you use the A6 as a spindle drive?
What size?
rpm for long term and load?
Posted: Wed Jun 25, 2025 4:19 am
by Cncsteve
Spindle drive 1000w
Very low rpm no load atm
Still testing
Posted: Wed Jun 25, 2025 4:39 am
by suntravel
Should not even get warm...
Posted: Wed Jun 25, 2025 9:03 am
by centroid467
Does it get hot while it is at zero speed?
Posted: Wed Jun 25, 2025 9:47 am
by Chaz
I dont have any servos that get hot, ever. Something isnt right with that ....
Posted: Wed Jun 25, 2025 9:49 am
by Cncsteve
It does not get hot at idle.
by Cncsteve
I’m commanding only 400rpm
Posted: Wed Jun 25, 2025 10:26 am
by Chaz
Cncsteve wrote: ↑Wed Jun 25, 2025 9:49 am
Can you check what load % (Amps or Torque) its running at 400 RPM? Anything mechanically binding?
Posted: Wed Jun 25, 2025 10:29 am
by Chaz
On my Panasonics, I can see a 'strength' figure, between 1 and 31 which equates to a table of PID settings - I find for spindle use, I run mine really low (like 1 or 2) otherwise I get odd hunting etc. Is there a similar setting on your drive?
