Acorn plasma without centroids THC
Posted: Thu Jun 19, 2025 1:24 pm
Hi all, is there a way to use the acorn board without centroids THC just don't have the money yet.
I do have a Proma THC that I have been using with Mach 3
I want to be able to touch down on the metal then have it fire the torch.
If I go into the wizard under and under "torch touch off" the input is set to 9 and cant be changed.
input 9 is only available if you bought their THC.
and with that you can have it touch off raise to a certain level and fire the torch.
