power to drives , whats needed
CNC1
Post by CNC1 »
power to drives , whats needed only have inputs and output signals came with acorn board .
drives i have (3) , RATTMMOTOR YPMC-1000W 220V Servo Motor Kit, Servo Motor with Servo Motor Driver, CNC Controller Kit
thank you :D
Re: power to drives , whats needed
Your servo drive manual, or the data plate on the side of each drive, should specify the input current rating.
A 1kW servo drive running on 220V 3-phase power will probably draw somewhere around 6A at its continuous rated output.
Current draw on single-phase power will be somewhat higher.
