Running backwards (resolved)
Anthony
CNC Control System Serial Number: (0616102337)
Post by Anthony »
When I push x-label goes left y+ table moves foward .120 vac I just purchased used any help?
Centroid_Liviu
Re: Running backwards
Post by Centroid_Liviu »
Please attached a current report of your system. From the Main Menu Press F7 Utilities, and then F7 Report.
viewtopic.php?f=60&t=1043
Anthony wrote: Thu Nov 30, 2017 12:55 pm When I push x-label goes left y+ table moves foward .120 vac I just purchased used any help?
What controller are you using? Acorn, All in One DC Oak?
Need more info on your setup.
Centroid Liviu asked for your report file, here are instructions to generate it:
viewtopic.php?f=60&t=943&p=4312&hilit=report#p4312
Centroid_Tech
Post by Centroid_Tech »
Based on their serial number of the control, this is an old Centroid CNCDRO control. It sounds like the control wasn't properly setup but that is why we need a current report from the system to see how the system is setup.
Centroid_Tech wrote: Fri Dec 01, 2017 12:30 pm Based on their serial number of the control, this is an old Centroid CNCDRO control. It sounds like the control wasn't properly setup but that is why we need a current report from the system to see how the system is setup.
My apologies. You were providing HIM with a report you had on file.
Anthony
Post by Anthony »
Thanks I fixed the axis moving backwords.
It is a cnc10 I tried to create a report like in the video but that is windows and this is not . It's on a used kneemill that's about all the info I have .or can locate at this time .
It had a dead cmos batery and now I'm in demo mode any sugestions?
Centroid_Tech
A dead CMOS battery shouldn't cause the control to be locked out of the CNC10 software. Please email us a current report from that system. Whether you have a Windows or Linux or DOS system, generating a report is pretty much the same. The only time it's different is on the older DOS systems because either the report function didn't copy all of the necessary files or the report function wasn't even supported. Perhaps the attached tech bulletin will help in generating a report.
193 Generating Report.pdf
(5.58 KiB) Downloaded 142 times
Anthony
Post by Anthony »
I attached the files
report.txt
(92.34 KiB) Downloaded 128 times
report.zip
(29.66 KiB) Downloaded 114 times
Centroid_Tech
Looking at the report, you do have permanent unlocks entered. Please verify that on the Options, it shows Permanent Unlock and Intercon as highlighted in green and that they say ON to the left of the option. If it does, then you have nothing to worry about as when the DEMO expires, those features will remain on. The report shows that it was generated on January 3, 2009. Please make sure that you correctly set the date and time in the BIOS settings. You can get to the BIOS settings by pressing the DEL key as soon as you power the system up.
Anthony
Post by Anthony »
Thank you for your help :D
