THC Voltage test question
Moderators: cnckeith, Joey
dovrosenberg
Post by dovrosenberg »
I did the THC stray voltage test with my primeweld cut 60 turned on( not firing). I got this plot. There is a little noise compared to not having the plasma turned on. It should be fine correct?
Thanks in advance
Joey
Plasma/Laser Lead
Re: THC Voltage test question
Post by Joey »
The Stray voltage looks to be under 10 counts and stable. Looks good from here.
dovrosenberg
Thank you!! It was low and consistent. Would I expect the plot to jump any if I triggered the torch?
Joey
Plasma/Laser Lead
Post by Joey »
The plot slowly rising would indicate the voltage is floating and un grounded.
You will see the voltage jump if the torch is fired.
