Doubt
BetterSword737
Doubt
Post by BetterSword737 »
I am making the connections for a 2-axes(X y Z) torm with a Turret Model LD48-C6140, to make the connections of the 4 positions that the turret has that has those 4 inputs so that the PLC knows in which tool it is and with a sensor limits in the lower part for when I make Home
My question is to make the connection of:
Input 1- Turret
Input 2-- Turret
Input 3-- Turret
Input 4- Turret
Can I do it directly on the H4 and H6 connector?
Thank you so much
Chaz
Re: Doubt
Post by Chaz »
All depends on the type of signal. Are these simple switches? Are they PNP etc? Fundamentally yes to the question but depends on what type of switch it is.
You also mention 2 axis but then name X y and Z ....
centroid467
Re: Doubt
Post by centroid467 »
Chaz wrote: Tue May 27, 2025 3:16 am All depends on the type of signal. Are these simple switches? Are they PNP etc? Fundamentally yes to the question but depends on what type of switch it is.
It is possible that the OP is more used to Spanish and the "y" means "and" in this case. Which seems likely considering that this sounds like a lathe turret.
Chaz
Re: Doubt
Post by Chaz »
Ah, thanks.
