G99 not working with encoder
WabecoD600
CNC Control System Serial Number: B83DF60BE626-0204259080
Post by WabecoD600 »
Hello,
I cant get my lathe to run G99, It stops with an unknown fault. I have a spindle encoder installed and the correct rpm read out on the screen. at one point I got an error n# 438. any ideas?
thanks Rob.
CentroidFrog
Tech Support
Re: G99 not working with encoder
Post by CentroidFrog »
Hi Rob,
Welcome to the forums!
Please post a fresh report.zip for us from your machine.
Here's how:
WabecoD600
Here is the report.
I added a - in front of the spindle encoder count, that seemed to solve the problem..?
CentroidFrog
Tech Support
What motors or drives are you using?
12,800 steps/rev is pretty high for most stepper motors.
WabecoD600
that is lead shine motors and drivers, with encoders, I have set the dip switches so that it steps 12800. They run pretty smooth, and the precission is very close to perfect without adjustement.
438 Spindle slave position error
The slaved axis moved too far in the
wrong direction during a
spindle-slaved move (such as in rigid
tapping). The job is cancelled.
Check Parameter 34 for an
incorrect plus/minus sign in front of
the encoder counts.
