Finished a job. Went to the next one to find the machine dead in the water. Reboot, etc and find home got lost. Z in particular.
It trips ok but does not make that last little move to home.
May not be pertinent but the wireless mpg doesn't seem to be recognized and the little rabbit/hare button is lit up but non functional.
Report attached.
Advice, tips?
Homing gone awry----SOLVED
- CNC Control System Serial Number: 101981
Dave Koehler
https://www.koehlerinjection.com
Re: Homing gone awry
That sounds like CNC12 thinks a probe or tool setter is tripped.
Remind us: do you have a probe and/or a tool setter? What type? Is it plugged into the control? Is it in a tripped condition?
Bingo
I have a tt1 and a dp4 tied into a cncsnw box.
The DP 4 had gotten mist oil on it which found it's way inside. Apparently it caused a short across the cable connector pin.
Cleaned it with some Deoxit and it's happy again.... for the moment anyway.
Dave Koehler
1 user liked this post
