Page 1 of 2
Z-Axis Break
Posted: Wed May 07, 2025 12:24 pm
by Blaze
Hello All,
I hope this message finds you well. I have a quick question and would appreciate your input.
I am working with a Leadshine Easy Servo Model: 86HSM85-BZ-E1, which has the following wiring:
Black = A+
Red = A-
Yellow = B+
Blue = B-
Additionally, there are two more wires:
White = +24V
Green = 0V, which I believe is for the brake connection per the attached document.
I have searched the Leadshine website for information on this motor and the 758 Driver but have not found any relevant details. If I am correct, should I connect the 2 additional wires for the brake as suggested in the pictures below?
Do I have to select the spindle brake on the Acorn wizard on Acorn
Also, is this Z-axis motor with brake function considered the spindle brake or just the Z-axis brake shown on G6 of this schematic ?
S15259.r4.pdf
(513.99 KiB) Downloaded 4 times
Thank you for your assistance!
Re: Z-Axis Break
Posted: Wed May 07, 2025 3:11 pm
by Chaz
Yep, there is a brake option on the Wizard for the axis that its being used on.
Re: Z-Axis Break
Posted: Thu May 08, 2025 4:28 am
by richardb15
The Z axis drive is just the Z axis drive, nothing to do with the spindle.
There is no need to use any brake wiring/connection on these motors and drives, just set the parameters to have a % holding torque and that will act like a brake for the axis. It is usually described by Leadshine as "Power-on lock shaft current percentage" and I usually use a value between 15 and 40% depending on what is being held/braked. Very high values can cause motor overheating, low values will cause backdriving and then give position errors.
So I wouldn't use any external brake or one set up in the Wizard. Just use the Leadshine drive parameters to set that lock torque.
Re: Z-Axis Break
Posted: Thu May 08, 2025 7:49 am
by ShawnM
richardb15 wrote: Thu May 08, 2025 4:28 am
Richard, the Z axis brake is to hold the motors position when the system is turned off or the drive is not enabled. It keeps the Z axis from dropping to the table when you power down the system.
The one diagram shows a brake connection but does not call out wire color. Blaze listed white as 24v and green as 0v but I don’t know where he got this info as it’s not posted.
Re: Z-Axis Break
Posted: Thu May 08, 2025 7:55 am
by richardb15
Richard, the Z axis brake is to hold the motors position when the system is turned off. It keeps the Z axis from dropping to the table when you power down the system.
Ah okay fair enough, I've never used these motor/drives on anything that has a mechanical arrangement that would lose position via gravity on power off
Re: Z-Axis Break
Posted: Thu May 08, 2025 8:03 am
by ShawnM
richardb15 wrote: Thu May 08, 2025 7:55 am
It all depends on the Z axis design, gearing and the dead weight of the Z axis assembly on a router or plasma table. I’m guessing this is not an issue on a mill.
Re: Z-Axis Break
Posted: Thu May 08, 2025 8:12 am
by ShawnM
Blaze wrote: Wed May 07, 2025 12:24 pm Hello All,
Black = A+
Red = A-
Yellow = B+
Blue = B-
White = +24V
Green = 0V, which I believe is for the brake connection per the attached document.11.jpg2 Z-Axis with Brake motor connection designation.jpg
Blaze, where do you see the wire colors and designation for the motor brake? I see in one diagram a connection for a brake but no where do I see wire colors called out.
Re: Z-Axis Break
Posted: Thu May 08, 2025 9:55 am
by Blaze
ShawnM wrote: Thu May 08, 2025 7:49 am
It's wonderful to hear from you again! I've been traveling for work, which left me with little time for myself. However, I am now back home for good and would like to continue the conversion.
You are correct that there are no color designations for the brake. I believe the white wire was marked as +24V and the green as “0”before I disconnected the machine for the upgrade to Acorn Six. If necessary, I can look for additional documentation to help identify these wires.
It appears that the Z-axis is holding its position well for now. I haven't encountered any problems, such as the axis dropping or failing to maintain its position when the machine is cycled on or off.
Re: Z-Axis Break
Posted: Thu May 08, 2025 9:57 am
by Blaze
Thanks all for your quick reply
Mr.Shawn It's wonderful to hear from you again! I've been traveling for work, which left me with little time for myself. However, I am now back home for good and would like to continue the conversion.
Re: Z-Axis Break
Posted: Thu May 08, 2025 6:31 pm
fyi.. a lot of electro magnetic brakes don't care about polarity of the dc voltage applied so they often have the same color wire for both wires.
