I want to set up position 8 on the tool table to have two offsets - I don't see how to have 2 tool 8.
I was told I could use 0808 and 0809 but I'm missing how to do this.
Setting up a turret with 2 hole holder at position 8
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
- Tech Support
Re: Setting up a turret with 2 hole holder at position 8
I believe what you may be looking for is here:
F1 Setup > F2 Tool Offset
Here you're able to set multiple offsets for whichever tool you'd like.
By changing which tool is associated with each offset you can call a tool change for Tnnoo.
Where nn is the tool number and oo is the offset.
So to call a tool change for tool 3 offset 5, we'd command: T0305
More info on this can be found on page 60 of the Lathe manual:
https://www.centroidcnc.com/centroid_di ... df#page=61
1 user liked this post
