Incremental Buttons Not Illuminating On Control Pendant
- Hickory CNC Controller: Yes
- CNC Control System Serial Number: none OEM
When we boot up the control, the incremental x1 x10 x100 do not have any lights on and do not allow any toggling. We found that if you turn on the wireless jog pendant Par# 218, they work. The problem is that it brings up a warning that the wireless jog pendant is not plugged in on bootup. I was checking if something needs to be adjusted in the PLC to correct this message on bootup or some other parameter.
- Tech Support
Re: Incremental Buttons Not Illuminating On Control Pendant
Please post a fresh report for us so we can see your configuration settings:
