Can a wmpg-6 be converted to Wmpg-4 <Answered, yes>
Moderators: cnckeith, Joey
keithmc72
CNC Control System Serial Number: 98038A53EE14-0303259150
Post by keithmc72 »
So long story short I returned my Cnc4pc thc and pts and got the Wmpg-6 because they did not stock the Wmpg-4. I asked them for the Wmpg-4 but all that had was the 6.
They agreed to do the swap for the mpg because we fought with Mach5 and the ess and their software for 3months with no resolution.
At that point I switched to centroid.
Is there a way to swap it for a Wmpg-4 or can it be changed by software and a new overlay attached?
Centroid188
Re: Can a wmpg-6 be converted to Wmpg-4
Post by Centroid188 »
The WMPG4 is no longer stocked the WMPG6 has replaced it and works fine in it place.
The installation instructions for WMPG6 can be found at:
https://www.centroidcnc.com/centroid_di ... ss_mpg.pdf
keithmc72
Post by keithmc72 »
I need the overlay for the plasma variant. Can that be purchased separately?
CentroidFrog
Tech Support
Post by CentroidFrog »
To my understanding you should be able to use a WMPG-6 as a WMPG-4 Plasma without any issues.
Just be sure to set it up as a WMPG-4 Plasma in the Wizard
We do have replacement overlays available.
If you'd like to purchase one contact support@centroidcnc.com to get one ordered.
Be sure to specify you want the Plasma overlay. Part# P180
keithmc72
Post by keithmc72 »
Yes it is working perfectly! Sent the email to order the overlay. Thank you!!
