THC Voltage Test Question (resolved)
Moderators: cnckeith, Joey
dovrosenberg
Post by dovrosenberg »
When I do the THC voltage test should the plasma machine be turned on with the torch off to check for stray voltage leaks?
Joey
Plasma/Laser Lead
Re: THC Voltage Test Question
Post by Joey »
You can look at a live view of the THC in the PID config Menu.
I think the path from the CNC12 home screen is setup-config- pid-pid config
dovrosenberg
Correct. Should the plasma be turned on with the torch off to see the view?
Joey
Plasma/Laser Lead
Post by Joey »
Either way.
Having the Plasma supply powered on is how I prefer it
