I/O presets
Posted: Sun Apr 20, 2025 2:23 pm
by terrymcc
I am starting the conversion of a machine to Acorn/CNC12. I am using an Ethernet 1616 board. In the Wizard, I can build the inputs and outputs. The system sees the 1616 and jumper testing shows it is working. I want to save this preset and load a simpler preset to start doing the basic bench test now that I have drives. When I select the Advanced I/O Configuration button to create this custom preset, it does not show that there is an expansion board and generates an error when I try to create or export the presets.
Any idea what I’m doing wrong?
Re: I/O presets
Posted: Sun Apr 20, 2025 2:40 pm
by Chaz
Struggling a bit with the question. Are you trying to set outputs so that you can use them later in some custom code?
Re: I/O presets
Posted: Sun Apr 20, 2025 2:43 pm
by terrymcc
No, I wanted to save my final presets so that I can load the basic bench test presets to test the drives. Then later, I can load the presets with all the needed I/O
Re: I/O presets
Posted: Sun Apr 20, 2025 3:10 pm
by Chaz
Save a report, then restore a report. That should work as it does all the mapping etc.
Re: I/O presets
Posted: Mon Apr 21, 2025 4:26 pm
what version of CNC12 are you using? please post a fresh report.zip.
and yes, its super easy to save/restore reports for different configurations.
or alternatively, simply copy/rename the entire cncm directory to quickly switch between them.
Re: I/O presets
Posted: Mon Apr 21, 2025 5:01 pm
by Allin1Chris
terrymcc wrote: ↑Sun Apr 20, 2025 2:23 pm
Hello, can you be more specific on the error that the wizard gives you? Maybe a snip or screen capture of the error, be very useful.
In addition, The expansion Board I/O may not appear in the Preset Box, however it will both save and load the Expansion Board I/O regardless.
