Allin1DC spindle brake and aux3
Gherrmann1995
CNC Control System Serial Number: A901495
Post by Gherrmann1995 »
Hello,
I can't get either the spindle brake time delay or AUX 3 button to actuate the spindle brake on my YCM40. The brake does actuate properly when the spindle is turned on and off minus there being no delay.
I have tried changing the PLC to add a time delay, changing parameter 700, and I have tried downloading CNC12 5.30 with no luck.
I've attached the SpinBrake PLC files I have tried and a final report.
Any help would be much appreciated.
Centroid_ALLIN1DC_Mill_SpinBrake-r5-1.src
(159.27 KiB) Downloaded 7 times
report_0008DC111213-0625243138_2025-04-15_19-52-06.zip
(10.22 MiB) Downloaded 5 times
Centroid_ALLIN1DC_Mill_SpinBrake-r5-OG.src
(158.35 KiB) Downloaded 5 times
Centroid_ALLIN1DC_Mill_SpinBrake-r5-2.src
(158.57 KiB) Downloaded 6 times
Re: Allin1DC spindle brake and aux3
i've asked Lucas to help you out.
Your "-2" program looks like it is headed in the right direction.
Maybe a delay of 300ms is just too short to notice? What happens if you install your "-2" program, and set P700 = 3000?
CentroidFrog
Tech Support
Post by CentroidFrog »
cncsnw wrote: Mon Apr 21, 2025 7:12 pm Your "-2" program looks like it is headed in the right direction.
I agree, the logic of "Centroid_ALLIN1DC_Mill_SpinBrake-r5-2.src" looks pretty good to me.
~1/3 of a second can be pretty hard to notice, I'd be curious to know if changing P700 to a higher value is noticeable.
