Re fiinish pass grayed out <Resolved, updated CNC12>
I have lathe pro but the finish pass will not let me select a tool ,its grayed out , i put in the amount of the pass speed and feed is there something i am missing here or what ? I have attched a report file
- report_E062345D5A00-0813215070_2025-04-03_16-47-43.zip
- (1014.11 KiB) Downloaded 5 times
1 user liked this post
Re: Re fiinish pass grayed out
Please provide the job file and describe the cycle you were trying to use, when the finish pass is locked out.
I have attached a job file for you ,i made up just now please let me know if you need anything else and Thankyou for your help .
If the finish pass is not working in Intercon will the controler block out the finish pass in a outside Gcode file produced by another software ?
- job file.cnc
- (929 Bytes) Downloaded 2 times
We will need the *.icn file (Intercon File)
Sorry i did not know this existed file attached.
- job file.lth
- (526 Bytes) Downloaded 2 times
I am not sure what file you need here but here is another one ,i made a new file Centroid tst file. nIf this is not what you need tell me how to get to it and what folder its in.
- Centroid tst file.lth
Some photos or video of what you are trying to do would be helpful. Here is your tst file displayed on my screen clearly showing the finish tool as T0101. The next image shows where i changed it to T0505.
hi you are using a pretty old version of CNC12 (4.80) , that probably has nothing to do with your issue but, sure
would be great to install the latest version of CNC12 and configure it with the Wizard so we are all using the same version and provide you with the best cnc tech support.
make screen shots of your existing v4.80 wizard save them and then install CNC12 v5.30. install your license file and then configure the v5.30 Wizard with the data in the v4.80 screen shots.
My screen shows the finish tool greyed out ,it looks like the cutter comp on your screen ,i will try and upgrade it this after noon , and send some screen shots .
Thank you for the help
Well updating fixed it ,thank you so much for suggesting that update it's been that way for a couple years, i have been sick for a long while and am just getting back into it .
Thank you to all that helped
2 users liked this post
