acorn cnc tool diameter not working? < use G41/42>
Posted: Sat Mar 29, 2025 5:02 pm
by myths420
hi do i need to do something special to turn on tool diameter? boring some holes there were off a hair tried to adjust tool diameter and redo them but this doesnt work. i ended up having to change tool size in fusion 360 and repost to do this. how i can i do this within acorn cnc?
would think that if fusion says tool is .2 for example and acorn defualt is 0 that adding acorn -.1 for example would make the tool .1 when running program but not sure.
Re: acorn cnc tool diameter not working?
Posted: Sat Mar 29, 2025 10:59 pm
by swissi
myths420 wrote: Sat Mar 29, 2025 5:02 pm hi do i need to do something special to turn on tool diameter? boring some holes there were off a hair tried to adjust tool diameter and redo them but this doesnt work. i ended up having to change tool size in fusion 360 and repost to do this. how i can i do this within acorn cnc?
When you create the tool path in Fusion 360, make sure you are setting the option “In Control” and not “In Computer”, otherwise the created G-Code does not use tool diameter offset commands and will not use the diameter offsets set in the CNC12 tool offset library,
-swissi
Posted: Mon Mar 31, 2025 1:40 pm
by myths420
swissi wrote: Sat Mar 29, 2025 10:59 pm
-swissi
ah ok ty, ill try that, going this route do i have to set all the tool diameters in acorn before hand or can i just set the offset if it needs to be adjusted.
Posted: Mon Mar 31, 2025 1:44 pm
by myths420
ok was looking at the setting and says if set to wear it will use fusion sizes but still inputs g41/42 so i can adjust the tool ware, dont remember seeing a setting for that in acorn but havnt looked specifically, sounds like this is what i was after if it uses tool diameter, use fusion sizes but let me fine tune in acorn.
