With G37 ON: Smaller corners and rounds the laser PWM is adjusted too low and doesn't burn sometimes
G37 OFF: Gives too much burning on the corners.
Is there a parameter that I can adjust to set how much the PWM is affected with G37 ON?
G37 Velocity Based PWM adjustments
