Hi everyone,
Today, my TMC AC servo motors arrived, and I started setting them up.
I configured them to run at **4000 steps per revolution**, which was straightforward.
I'm aiming for a **G0 speed of 8000 mm/min**, but unfortunately, **Centroit Acron only allows me to set 1200 mm/min**.
Here are the details of my setup:
- **Ballscrew pitch**: 5 mm/rev
- **Steps per revolution**: 4000
- **Controller setting**: 400,000 steps/sec
Based on my calculations:
- 1200 mm/min = **20 mm/sec**
- 20 mm/sec / **5 mm per rev** = **4 rev/sec**
- **4 * 4000 steps = 16,000 steps/sec**
This is far below the 400,000 steps/sec limit, so I don't understand why I can't set a higher speed.
Does anyone have an idea what I might be doing wrong?
Thanks in advance!
Issue with TMC AC Servo Motors and Centroit Acron - Speed Limitation? <resolved >
- CNC Control System Serial Number: B83DF60BBF62-0128259041
- Tech Support
Re: Issue with TMC AC Servo Motors and Centroit Acron - Speed Limitation?
Hello there,
To help us get a little more info on your system please post a fresh report.zip and any schematics or manuals you're using.
I think the settings regarding steps/revs and the overall turn ratio are fine. When I move the axis by 5mm, the drive completes one full revolution.
- report_B83DF60BBF62-0128259041_2025-03-13_16-07-13.zip
- (1.02 MiB) Downloaded 1 time
- Tech Support
Would you be able to try this on our newest version of CNC12? v5.30
In 5.26 there was a bug where for metric systems the axis max rate was being calculated for imperial units:
viewtopic.php?f=60&t=11141&p=97639&hili ... .26#p97639
Yes this is solved in 5.30
I recommend anyway to start with the latest version software.
Re: Issue with TMC AC Servo Motors and Centroit Acron - Speed Limitation? <resolved >
quick update – the issue was actually caused by the software version!
now everything is working perfectly.
Thanks a lot for your help !
