Wiring laser on acorn
usinart
Post by usinart »
Hi all ,
I'm wiring a laser on my machine and I have a question about that.
on file s15061 laser schematic vdc power supply plug in to relay board on out 1 center pin .
on file s15102 motor schematic a estop plug into out 1 center pin .
question
should I move one of the wire ? if yes where .
should I plug it together ?
report_B83DF6126706-1119204064_2025-03-07_12-11-06.zip
(1.25 MiB) Downloaded 3 times
usinart
Re: Wiring laser on acorn
Post by usinart »
I modified the wiring for that .
what is the mdi that I should use for making start .
Now mothing run no fan no light .
have and idea ?
I m stock
silver2row
CNC Control System Serial Number: 6665
Post by silver2row »
Hello...
I cut my wiring for IN2 and that is easily seen on your last photo you produced here. I used an E-Stop and then used PWM and GND from the DB25.
Seth
