Acorn carousel atc
supermaxcnc
Acorn carousel atc
Post by supermaxcnc »
Hey guys trying to get my atc working and everything seems to working but it get stuck and carousel in it comes in to spindle and backs off immediately which is strange if i manually toggle the solenoid it will continue with the toolchange
supermaxcnc
Re: Acorn carousel atc
Report added i also have video i can post
report_3484E41C0C27-1003248579_2025-03-04_15-23-52.zip
(1.04 MiB) Downloaded 2 times
supermaxcnc
After messing with it a bit more today I have narrowed it down to carousel in output is not staying latched after the umbrella meets the spindle. If I manually operate the pilot on solenoid the toolchanger works perfectly and completes the cycle very strange the solenoid is brand new as well.. is this a software issue??
supermaxcnc
supermaxcnc
supermaxcnc
First video shows issue. 2nd shows it working with me being a part of the plc 😀
The Acorn PLC program assumes a dual-coil solenoid valve with detents (or 3-position spring-to-center with closed center). It turns off the "ATC_CarouselIn" solenoid output as soon as it sees the carousel as advanced; and later turns on the "ATC_CarouselOut" solenoid output when it needs to retract the carousel out of the way.
Since your machine apparently has a single-coil solenoid that returns to the "retract out" position as soon as you turn off the "advance in" coil, you will need to make changes to the PLC logic in the carousel in/out section of your PLC program.
supermaxcnc
Thanks for the help that makes sense. Would it make more sense to put a dual coil solenoid?
supermaxcnc
Does anyone know if I need closed or pressure or exhaust center valve for this application?
I would use a two-position detented valve, so that the center state is not particularly important.
If you have to use a three-position spring-to-center valve, a closed center would probably be best, to improve the chances that the carousel will stay put after the coil is turned off.
