Offline version of INTERCON Number 2
lilb93
CNC Control System Serial Number: 0216041209
Post by lilb93 »
Got in I guess is the dongle, where do you find the software???? Tried tech support they said they will call back. But when is the question.. :oops:
Barnesville, PA.
I always thought it would take longer to grow old.
Centroid_Tech
Re: Offline version of INTERCON Number 2
Post by Centroid_Tech »
You can download the latest CNC11 v3.16 software here http://www.centroidcnc.com/centroid_diy ... loads.html. When you get to the section where it asks you what you want to install, select either the Mill or Lathe DEMO. That is the Offline Intercon software. Do you happen to know who you spoke with in tech support? Do you happen to know what your control serial number is as there may be a chance that there will be a backwards compatibility issue between the Offline Intercon v3.16 and whatever version of Intercon you have running on your control.
lilb93
Post by lilb93 »
0216041209 Thats what is on the main screen tried to run it on XP says not a valid win32 application.
Barnesville, PA.
Centroid_Tech
For future reference, your Centroid control serial number is 3606. Our database shows that system is running CNC10 v2.36. In order to avoid backwards compatibility issues, I will email you the Offline Intercon v2.36 via filemail.com as I can't attach it due to its size. It is Windows XP compatible. That particular version of Offline Intercon is not, however, Windows 7, 8, or 10 compatible.
