I know how to get a user variable using GetSystemVariable.
Is there a way to Set a user variable before a job is run. I can't find a SetSystemVariable.
Thanks!
SetSystemVariable?
- CNC Control System Serial Number: B4107B77A373-0905248481
SetSystemVariable?
Re: SetSystemVariable?
Yes, CNCPipe.Job.SetSystemVariable(...) which has an overload for the string variables as well. Please note that #1-#149 are initialized to 0 before the beginning of a job and not every variable is writeable.
More information on variables can be found in the manual in section 11.2.16: https://www.centroidcnc.com/centroid_di ... manual.pdf
I'm not finding it in the documentation when trying to use SetSystemVariable.
Results in:
'CNCPipe.Job' does not contain a definition for 'SetSystemVariable' and no accessible extension method 'SetSystemVariable' accepting a first argument of type 'CNCPipe.Job' could be found (are you missing a using directive or an assembly reference?)
public CentroidAPI.CNCPipe.ReturnCode SetUserVariable(int variableNumber, double newValue)
var cncPipe = new CentroidAPI.CNCPipe.Job(m_pipe);
return cncPipe.SetSystemVariable(variableNumber, newValue);
What version of software are you using? The SetSystemVariable call was added in CNC12 v5.24
1 user liked this post
We're using 5.22 ... time to upgrade?
If you want the single line call, yes. If you're not interested in upgrading, you can cheese it a little with
which would have the same effect though is much slower to perform.
string command = "#" + variableNumber + " = " + newValue;
return cncPipe.RunCommand(command, "C:\\cncm", false);
No thank you, I'm already writing multiline "macros" to do something similar... this is too good.
