Build Thread - Hint-Els 4 Axis Dental Machine - Granite / Epucret, 80K RPM Spindle / ATC
Chaz
Post by Chaz »
Firstly, many thanks to 'Sliding Head' for the machine and transport.
What an interesting one.
4 Axis machine, 80K spindle. Single phase, steppers, some form of ATC collet system. Titanium 'work holding', what a lovely bit of engineering. It also has some form of tool probe in the back behind the collets.
So, naturally thinking to go Centroid Acorn. What I am unsure about is why there might be two X Axis drives. Cant find a manual for the spindle drive as yet, so not sure what that needs in terms of speed reference etc.
*EDIT*, so the '2nd' X Drive will be for A, probably a failed drive that's been replaced but not relabled.
Any reason why a standard Centroid Acorn board / system wouldnt work here?
Thanks in advance.
Chaz
Re: Build Thread - Hint Els 4 Axis Dental Machine - Granite / Epucret, 80K RPM Spindle / ATC
Post by Chaz »
And a few more pics.
Muzzer
Post by Muzzer »
@chaz I see you and your new machine have made it here from mycncuk via migwelding. Where are you in the UK?
Chaz
Post by Chaz »
Yep. Who / what is Migwelding (talking about their forum)? I'm in Oxfordshire.
This is a slightly different model, but there is a reasonable chance it will have the same 15-pin connector.
See section 7.1 of the attached manual (page 10 in the PDF file)
Jaeger_FU_07-00T_08D.pdf
(2.04 MiB) Downloaded 1 time
Chaz
Post by Chaz »
cncsnw wrote: Sat Feb 22, 2025 7:18 pm This is a slightly different model, but there is a reasonable chance it will have the same 15-pin connector.
Amazing, thank you. Taking a look.
Chaz
Post by Chaz »
So taking a look, its 0-10V, nice. Pin 11 for the + side of the input, does it look like pin 8 (ground) for the other wire? I dont see another GND / 0V option.
Pin 12 is Start (Same ground or perhaps related to pin 6)?
I wonder if the 24V on pin 6 is needed / mandatory or only for the outputs / relay statuses?
Chaz
Post by Chaz »
I suppose if I take panels off tomorrow I might be able to find the wire pairing from the existing controller (unless it just goes into the DB15 and no way to tell).
Muzzer
Post by Muzzer »
Chaz wrote: Sat Feb 22, 2025 3:51 pm Yep. Who / what is Migwelding (talking about their forum)? I'm in Oxfordshire.
Ah, sorry, was confused. There were 2 of these machines looking for a new home. The other one seems to have gone to m_c up in Scotland who posted about it on the mig-welding site https://www.mig-welding.co.uk/forum/thr ... st-2554018
I wonder what he will do with his!
cool, please put all the photos in a photo album (and you can keep adding to the album!) then there is one link to all the photos. :-)
