Acorn freezing up... <travel limits?>
supermaxcnc
Post by supermaxcnc »
Hey guys been running a vmc on a acorn for a while now it works great other than sometimes after running long programs then starting the next program it does unusual things spindle will turn very slow and feeds are slow sometimes it will feed hold automatically and won't respond then it will sometimes force computer into not responding. A simple reboot always solves it. Im running a ELO allin1pc with i5 processor and input would be appreciated!
Re: Acorn freezing up...
Please post a current report from the machine so we can see what you are working with.
supermaxcnc
Report added
report_3484E41C0C27-1003248579_2025-02-17_08-06-33.zip
(1.36 MiB) Downloaded 4 times
It looks like it's waiting on the orient signal from the spindle.
supermaxcnc
Re: Acorn freezing up... <waiting on orient signal from spindle>
The toolchanger isent fully working yet. It freezing doesn't seem related to that
supermaxcnc wrote: Mon Feb 17, 2025 3:44 pm The toolchanger isent fully working yet. It freezing doesn't seem related to that
you'll have to better define freezing, got a video?
error log shows you are up against the software travel limits?
(1) 02-16-2025 11:24:10 CNC12 Acorn Mill v5.10
(1) 02-16-2025 11:24:11 407 X+ limit (#50047) tripped
(1) 02-16-2025 11:24:11 407 Y+ limit (#50047) tripped
(1) 02-16-2025 11:24:11 407 Z+ limit (#50047) tripped
(1) 02-16-2025 11:24:11 406 Emergency stop detected
(4) 02-16-2025 11:24:36 907 Y axis travel exceeded
(4) 02-16-2025 11:24:37 907 Z axis travel exceeded
(4) 02-16-2025 11:25:08 907 Y axis travel exceeded
(4) 02-16-2025 11:25:55 907 Y axis travel exceeded
(4) 02-16-2025 11:32:38 907 Y axis travel exceeded
(4) 02-16-2025 11:32:39 907 Y axis travel exceeded
(4) 02-16-2025 11:53:13 907 Z axis travel exceeded
(4) 02-16-2025 11:59:59 907 Y axis travel exceeded
(4) 02-16-2025 12:00:05 907 Y axis travel exceeded
(4) 02-16-2025 12:09:02 907 Y axis travel exceeded
(4) 02-16-2025 12:10:53 907 X axis travel exceeded
(4) 02-16-2025 12:11:47 907 Y axis travel exceeded
(4) 02-16-2025 12:14:03 907 Z axis travel exceeded
(1) 02-16-2025 12:33:28 Exiting CNC and shutting down machine (68)
(1) 02-17-2025 7:59:47 199 CNC Started
(1) 02-17-2025 7:59:55 CNC12 Acorn Mill v5.10
(1) 02-17-2025 7:59:55 406 Emergency stop detected
(1) 02-17-2025 8:02:25 SLOW_JOG_SELECTED
(1) 02-17-2025 8:02:27 FAST_JOG_SELECTED
(1) 02-17-2025 8:06:33 Creating report...
Re: Acorn freezing up... <travel limits?>
from your first post that sounds like a PC issue, try a different PC, run the Centroid PC Tuner on it and copy the CNCM directory from old PC to new PC and you are good to go.
fyi..the PC your are using has an I3 processor.
Operating System info:
Edition : Windows 10 Pro (10.0)
Version : 2009
OS Build : 19045.4780
Memory info:
Total physical memory : 8511148032
Available physical memory : 6240354304
Processor info:
Intel(R) Core(TM) i3-6100TE CPU @ 2.70GHz
Number of cores : 2
Number of logical processors : 4
Display info:
Display Size: Width 1920 Height 1080
Scale Setting: 100.000000%
Taskbar is not hidden
supermaxcnc
I was afraid pc might be issue. Is I3 Not enough?
I3's Single Thread Rating of 1636 does meet Centroid's minimum of 1500 for mills.
