What is the best way to learn CNC 12 to get up and running? I'm new to CNC and would like some idea on where to start or who explains things in an easy-to-understand format.
Thanks for the help
what is the best way to learn cnc 12
- CNC Control System Serial Number: 98f07b91ff38-0322237053
1 user liked this post
- Web Developer
Re: what is the best way to learn cnc 12
I moved this thread from the Knowledge Base into the Acorn Forum.
IMHO a good way is to read the manual. ( it is free )
Get Tool and Part Setup working.
Follow the Intercon examples.
Make your own simple parts with Intercon.
Learn to read and understand the g-code Intercon is posting.
Learn CAD / CAM with a system known to work easy with centroid.
Maybe Vectric for routers or fusion 360 for mill and lathe.
