Ethernet Switch - Power / Wiring
Chaz
Post by Chaz »
Hi,
I've got one of the DC powered switches with my Eth1616 which is a welcome addition. Ive been using another switch in the meanwhile but now keen to install this one. Its got two sets of inputs, which do I use on 24V DC please? The docs show the spec of it, not any wiring info. I also dont see any wiring info amongst the Centroid diagrams.
Chaz
Re: Ethernet Switch - Power / Wiring
Post by Chaz »
This looks like the same switch, perhaps different label but same connector etc. On this it suggests that V1 and V2 are 2 different sources in case you wanted resilience? So use use V1 - as GND and V1 + as 24V DC?
https://www.amazon.co.uk/MokerLink-Indu ... r=8-5&th=1
Centroid_Liviu
Post by Centroid_Liviu »
Please see the attached schematic for wiring the Switch.
s15004.r2.pdf
Acorn + Ether1616 wiring schematic
(167.68 KiB) Downloaded 14 times
Chaz
Post by Chaz »
Perfect, thank you, as assumed. Not powered it on yet, still busy rewiring.
