Allin1DC, Oak, MPU11 related documentation links.
Centroid CNC Manuals.
https://www.centroidcnc.com/centroid_di ... nuals.html
How to Configure Windows 10/11 for CNC control use.
https://www.centroidcnc.com/dealersuppo ... ds/309.pdf
Centroid CNC Hookup and System schematics
https://www.centroidcnc.com/centroid_di ... .php?term=
use the search!
Centroid CNC software downloads.
Encoder Basics
https://centroidcncforum.com/viewtopic.php?f=64&t=4
DC servo motor Encoder retrofit upgrade
https://www.centroidcnc.com/sem_dc_serv ... rofit.html
Centroid CNC support youtube video channel.
https://www.youtube.com/@CentroidSupport
20 year old mill training video, the basics still apply. WCS, Tool heights etc.
for Bed Mill
for Knee Mill
Oak Bench Test Video.
https://centroidcncforum.com/viewtopic.php?f=64&t=3238
Allin1DC control installation video.
https://centroidcncforum.com/viewtopic.php?f=64&t=2421
Machine Tool Coordinate Systems and Conventions.
https://centroidcncforum.com/viewtopic.php?f=64&t=3638
Centroid Tech Bulletins
https://www.centroidcnc.com/centroid_di ... browse.php
Intro to Macro Programming
https://www.centroidcnc.com/centroid_di ... amming.pdf
CNC12 Virtual Control Panel Users Guide
Tool Height, WCS Part Zero, Machine Coordinate explanation
https://www.centroidcnc.com/centroid_di ... rement.pdf
WCS made easy
https://www.autodesk.com/products/fusio ... made-easy/
Centroid G-code Smoothing users manual.
Using the CNC12 PLC Input Output diagnostic screen documentation.
https://www.centroidcnc.com/centroid_di ... screen.pdf
Marty's CNC Garage Video Channel
https://www.youtube.com/channel/UCTNt9I ... GVQ/videos
newbie Centroid PLC programming video series..
How to add a simple safety switch input to a PLC program
https://www.centroidcnc.com/dealersuppo ... ds/314.pdf
CNC12 PLC programming manual http://www.centroidcnc.com/centroid_diy ... manual.pdf
PLC Detective users guide.
https://www.centroidcnc.com/downloads/c ... kstart.pdf
1936hotrod
Re: Allin1DC, Oak, MPU11 related documentation links.
Post by 1936hotrod »
Just doing the voltage bench test on the allin1 dc I put in my mill and a line says I need to close the door first. I don’t have a door switch. Is there a parameter I need to shut off so I can continue my setup. Thanks
1936hotrod wrote: Mon Apr 28, 2025 2:39 pm Just doing the voltage bench test on the allin1 dc I put in my mill and a line says I need to close the door first. I don’t have a door switch. Is there a parameter I need to shut off so I can continue my setup. Thanks
please start a new thread
