How to add "Optional Stop" and "Block Skip" buttons to VCP?
RTech
CNC Control System Serial Number: just ordered
Post by RTech »
Is there an easy way to add an "Optional Stop" and "Block Skip" button to the VCP? I have edited the VCP to add the button images, but I don't see an easy way to make them work.
I have looked through the PLC and have found how much code is there for the "Single Block" button. Will I have to mimic this code for each of the buttons or is there an easier way to do this?
The reason I would like to add them to the VCP is that it is very convenient to have all these buttons in one area when first running a program and testing it out. I also think having these buttons grouped together adds an element of safety...less time required to search for the buttons on the screen.
Any help is appreciated.
ASPeters
Re: How to add "Optional Stop" and "Block Skip" buttons to VCP?
Post by ASPeters »
RTech wrote: Tue Jan 07, 2025 11:02 am Is there an easy way to add an "Optional Stop" and "Block Skip" button to the VCP? I have edited the VCP to add the button images, but I don't see an easy way to make them work.
The Optional Stop and Block Skip functionality is completely internal to CNC12. There is not a way for the PLC or VCP to alter this currently.
RTech
Post by RTech »
Well, that's not the answer I was hoping for. I do think it would be a great feature to add some time in the future.
You can roll your own optional stops, to work with a VCP key and just ignore the setting on the CNC12 run menu.
All you need is a VCP key that turns a bit (such as its own LED) on and off; and an M1 macro that does an M0 if (and only if) that bit is on.
