7075-T651 Aluminum
RJS100
7075-T651 Aluminum
Post by RJS100 »
Quick question. Most of the work I have done so far has been with 6061 aluminum. I am starting a small project with 7075-T651 aluminum. When I look up the speeds and feeds using the CNC Cookbook, they appear to be the same for 6061 as 7075.
Is this accurate? I was planning on using the same 3 flute aluminum specific YG1 end mills.
Thanks... Richard
spikee
Re: 7075-T651 Aluminum
Post by spikee »
7075 is harder, so it wants to stick less vs regular t6061.
I.e. you can feed even quicker if you wanted to.
RJS100
Post by RJS100 »
Thanks so much. Really appreciate that.
spikee
Post by spikee »
you can use millalyzer or tools like that to get a more informed decision.
RJS100
Post by RJS100 »
Thanks.
