i updated the Acorn Axis Pairing and Squaring manual to match the Hardware Pairing with Autosquaring support we added in
i updated the Acorn Axis Pairing and Squaring manual to match the Hardware Pairing with Autosquaring support we added in CNC12 v5.2x
https://www.centroidcnc.com/centroid_di ... _guide.pdf
you could always make a Hardware Paired axis auto square with CNC12 but you had to DIY it. as in do-it-yourself by writing the custom home program (macro) that disconnected one side of the paired axes and then moved to seek a switch to square up each side etc... In v5.20 we added selections in the Wizard Homing and Pairing menu so the Wizard will now do-it-for-you. <aka DIFY?>
