Trigger an E-Stop
Make your own CNC Control Apps
Gerral
CNC Control System Serial Number: B4107B77A373-0905248481
Trigger an E-Stop
Post by Gerral »
Is CentroidAPI.CNCPipe.Job.CancelExecution the best way to simulate hitting the E-Stop or is there a better way. I'd want it to do the equivalent to a reset too, but don't see that in the API.
As ever thanks for your comments and remarks.
ASPeters
Re: Trigger an E-Stop
Post by ASPeters »
Gerral wrote: Wed Dec 18, 2024 10:34 am Is CentroidAPI.CNCPipe.Job.CancelExecution the best way to simulate hitting the E-Stop or is there a better way. I'd want it to do the equivalent to a reset too, but don't see that in the API.
Job.CancelExecution cancels the currently running job only. It effectively does the same operations as cycle cancel would.
There is no way to perform an E-Stop programmatically.
To perform a Reset programmatically, you can use
CNCPipe pipe = new CNCPipe();
pipe.plc.SetSkinEventState(56, 1); //Sets reset
//Additional logic
pipe.plc.SetSkinEventState(56, 0); //Clears reset
Skin Event 56 is currently the reset skin event for acorn. Please double check what your reset button is set to under C:\cncm\resources\vcp\Buttons\reset\reset.xml
Please note that the plc requires 20-30 ms to register the skin event change.
