H100 vfd
- CNC Control System Serial Number: 300003
H100 vfd
I have an Amazon vfd H100, I would like to run it on my spindle motor if possible, where does the vfd 0-10 dc+ and com wire into on this inverter. Any wiring help would be very much appreciated
Re: H100 vfd
COM and AI1 as noted in the lower left of the diagram.
Re: H100 vfd
You may need to program parameters in the vfd for it to work the way you want. Normally they are set up for keypad of the vfd to turn on and set speed.
Ken
Re: H100 vfd
Where COM = "GND".COM and AI1 as noted in the lower left of the diagram.
You do not connect anything to P12 or AI2.
