When the CNC12 Software began to uploading after the connection with the Acorn board show this massage. " Invalid Command Line argument "
The acorn board is fresh only few days of purchase, I only installed the software no configuration is only bench test. I press "OK" and the upload continue without any issue.
Invalid Command Line Argument
- CNC Control System Serial Number: M39 A901105
- report_3484E41A16E2-1007248592_2024-11-24_15-33-09.zip
- (970.14 KiB) Downloaded 6 times
Re: Invalid Command Line Argument
hi.
please run the Centroid PC Tuner on the CNC PC.
The file C:\cncm\startupOptions.ini has an erroneous empty line with a bunch of tab spaces in the first line. Delete the first line so the file only reads a single line:RoblesEng. wrote: ↑Sun Nov 24, 2024 7:56 pm When the CNC12 Software began to uploading after the connection with the Acorn board show this massage. " Invalid Command Line argument "
--adjustfortaskbar
1 user liked this post
