2 wire proximity sensor
Stew260
CNC Control System Serial Number: Acorn 8599
Post by Stew260 »
On my lathe conversion using an Acorn board i need to use a 2 wire sensor (It’s a specific size and shape to fit in the lathe tool turret) and I cant find a 3 wire alternative. The manual says to not use a 2 wire sensor. Can anyone advise if a 2 wire will in fact work or a solution.
Gary Campbell
Re: 2 wire proximity sensor
Post by Gary Campbell »
Post the data sheet for the component
Stew260
Post by Stew260 »
With sensor data sheets.
robtown
CNC Control System Serial Number: F045DA78F172-1129181385
Post by robtown »
I have no idea if this will work for you or not.
Stew260
Post by Stew260 »
Many thanks. I did look at that video and think that it may still upset the acorn due to the voltage drop but will research this again to make sure.👍
Stew260
Post by Stew260 »
Now sorted. Thanks
