Get Dro Machine cordinates
Make your own CNC Control Apps
Ryan Patterson
Post by Ryan Patterson »
I am making progress in understanding the API. Below is the code that will retrieve the machine coordinates. DroStrings will return an array of the machine cordinates.
        Dim cnc12Pipe As New CNCPipe()
        Dim droObject As New CentroidAPI.CNCPipe.Dro(cnc12Pipe)
        Dim droType As CentroidAPI.CNCPipe.Dro.DroCoordinates = droObject.DroCoordinates.DRO_MACHINE
        Dim droStrings As Tuple(Of String, String, String)() = Nothing
        Dim result = droObject.GetDro(droType, droStrings)
Centroid_Jacob
Web Developer
Re: Get Dro Machine cordinates
Post by Centroid_Jacob »
Visual Studio gave me a warning about this line:
Because of the droObject reference but it ran fine for me. To avoid this warning, Import CentroidAPI.CNCPipe.Dro and then change the reference in your typing to:
Dim droType As CentroidAPI.CNCPipe.Dro.DroCoordinates = DroCoordinates.DRO_MACHINE
Then you would call:
droStrings(0).Item1 ' to get the first Axis Label
droStrings(0).Item2 ' to get the first Axis Machine Position
droStrings(0).Item3 ' to get the first Axis Load Meter readout.
I would put it all together as a function, like so:
Imports CentroidAPI.CNCPipe.Dro
Function GetDroReadout(ByVal axis As Integer) as String
    ' reuse existing pipe to prevent using up all of CNC12's API Pipes
    Dim droObject As New CentroidAPI.CNCPipe.Dro(m_pipe)
    Dim result As ReturnCode = droObject.GetDro(droType, droStrings)
    Return droStrings(axis).Item2
End Function
Where axis is 0-7, Default Mill/Router config would be 0 = X, 1 = Y, 2 = Z but may vary depending on machine purpose and setup.
Ryan Patterson
I suppose to protect against the Axis not being in a set location in the array a For each loop could be used. But of course the labels of each axis would need to cover all the possible (U,V,W,X,Y and Z)
        For Each dro As Tuple(Of String, String, String) In droStrings
            ' Access each component of the tuple
            Dim axis As String = dro.Item1
            Dim position As String = dro.Item2
            Dim additionalInfo As String = dro.Item3
            Select Case axis
                Case "X"
                    Console.WriteLine("X=" & position)
                Case "Y"
                    Console.WriteLine("Y=" & position)
                Case "Z"
                    Console.WriteLine("Z=" & position)
                Case "C"
                    Console.WriteLine("C=" & position)
            End Select
        Next
Centroid_Jacob
Web Developer
Depending on exactly how you want it to function, I would drop the 'select case' and use 'axis' to print the label (or use it as a lookup if you have a control or dictionary/collection/array of axes).
The 'for each' loop is the way to go in my opinion, or do a 'for i as integer = droStrings.Length - 1' and use i as your index to get/set the label in whatever dictionary/collection/array you are using to manage your DRO coordinates.
Many solutions for the same 'problem'.
