Spindle warm up advice.
robtown
CNC Control System Serial Number: F045DA78F172-1129181385
Post by robtown »
I've got a new spindle mounted up and running.
This is new for me as I've spent the last 20 years using a Porter Cable 3-1/4 hp as my spindle.
Going through the centroid warm up the first thing it prompts is to remove the tool. My setup is not ATC by the way.
Is this prompt more for the ATC users, or should I be warming up without a tool in the collet?
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Re: Spindle warm up advice.
Post by Nigelo »
For safety reasons I prefer to run without a tool installed but ALSO with collet nut removed
Hope this helps
Nigel
This depends on the spindle, I would mine not run without a toolholder and a loose drawbar.
Nigelo
Post by Nigelo »
suntravel wrote: Sat Nov 09, 2024 4:45 am This depends on the spindle, I would mine not run without a toolholder and a loose drawbar.
Of course you are correct Uwe (as usual :mrgreen: )
I should have stated that my router spindle has an ER25 collet chuck and not fixed toolholders i.e. no drawbar.
Hope this helps
Nigel
