Full Depth or Half
RJS100
Full Depth or Half
Post by RJS100 »
I am setting up the CAM for a part that is 1.5" thick. I initially planned on running a 3D adaptive and machining a depth of .75" in depth, then flipping the part over and repeating the process. See attached. I then remembered that I have a long end mill and could machine the whole depth at once. Is there an advantage of doing half and half versus the full depth?
Thanks..Richard
Re: Full Depth or Half
This depends on how rigid your machine is and on the chip evacuation of the endmill...
If your machine can do it, full depth spreads the wear over more of the cutter.
