Ohmic touch off not responding
Moderators: cnckeith, Joey
_Duke_
CNC Control System Serial Number: 0035FF8A4D57-0713203500
Post by _Duke_ »
I've just updated to v5.2, I input all my old values from the previous install.
Now whenever I go to probe the z with the ohmic torch tip, it keeps going and crashes and trips the breakaway.
On the Alt+i diagnostic screen, the #9 input works as it should when I ground out the tip.
Is there some new setting I have to change in 5.2?
report_0035FF8A4D57-0713203500_2024-11-03_17-41-47.zip
(6.98 MiB) Downloaded 6 times
Joey
Plasma/Laser Lead
Re: Ohmic touch off not responding
Post by Joey »
Is the THC set to Installed in the Profile manager's THC Config settings?
_Duke_
Post by _Duke_ »
Ooh good call, I did forget to enable that!
But unfortunately that didn't fix the issue
Joey
Plasma/Laser Lead
Post by Joey »
Hmmm ... Did you hit "done" at the bottom THC Config menu?
That should of been the trick.
The Input state is not forced in the alt-i screen correct?
_Duke_
Post by _Duke_ »
Wow, that was super weird.
It definitely saved the settings in the THC menu.
I opened up the alt+i menu once more, forced it with ctrl+alt+i, tried again- same result. Then I hit ctrl+alt+i to unforce it again, and now it's working. Joey you're a genius!
