Needing help regarding a Bridgeport Boss with a DP4 probe. RESOLVED
KEITH_TSE
CNC Control System Serial Number: OAK: 104625, CPU7: 20295
Post by KEITH_TSE »
Upon EVERY start up, the control thinks the probe is connected when it's actually not.
No programs will run, the spindle will not start, "jogging while probe detected" is displayed, etc. until I connect the probe and touch the stylus to cycle the LED.
Any ideas what could be causing this?
Thanks a lot.
centroid467
Re: Needing help regarding a Bridgeport Boss with a DP4 probe.
Post by centroid467 »
Please post a current report from the machine.
Were there any changes to the system recently or did it just start happening on its own?
KEITH_TSE
Post by KEITH_TSE »
Hopefully below is what you're looking for. Let me know if its not.
It's always done it and I'm now taking the time to fix it.
Report Date:
Thu Sep 5 09:51:56 UTC 2024
Operating System:
CNC Linux v2.30
Last updated: Wed Jan 24 11:02:50 UTC 2007
All software installed in /cncroot including, but not limited to,
CNC10, Intercon, CNCEdit, XPLC Compiler, XPLC Executor is
Copyright(c) 2004 Centroid Corporation. All rights reserved.
DUPLICATION OR MODIFICATION OF SOFTWARE IN /cncroot IS PROHIBITED.
All other software contained on this system comprises a Linux
operating system (CNC Linux) and is covered under miscellaneous
licenses including, but not limited to, the GNU General Public
License. See the individual packages on the accompanying Source
RPM CD's and the notices contained therein for information on
Use, Copying and Distribution.
See /cncroot/c/COPYRIGHT for details.
CNC10CONV v. 2.30 - Centroid configuration file utility
CNC10 Uniconsole-2 v. 2.30 setup file for CPU7 serial number 1220040412*
DRO display units: Inches
Machine units: Inches
Max spindle (high range):
4200.0
Min spindle (high range): 500.0
Machine home at pwrup: Yes
PLC type: Normal
Console type: Uniconsole-2
Jog panel required: Yes
Screen blank delay: 100
Remote Drive & Directory: G:
Axis Slow Jog Fast Jog Max Rate Deadstart Delta Vmax
(in/min) (in/min) (in/min) (in/min) (in/min)
1 24.0000 100.0000 260.0000 5.0000 5.0000
2 24.0000 100.0000 270.0000 5.0000 5.0000
3 24.0000 100.0000 200.0000 5.0000 1.4400
4 3600.0000 7200.0000 7200.0000 5.0000 5.0000
5 24.0000 100.0000 200.0000 5.0000 5.0000
Axis Label Motor Encoder Lash Comp. Limit Home Dir Screw
revs/in counts/rev. (inches) - + - + Rev Comp
1 X 4.9960 8000 0.0000 2 0 2 0 Y N
2 Y 5.0000 8000 0.0018 0 3 0 3 Y N
3 Z 5.0000 8000 0.0000 0 6 0 6 N N
4 N 0.2500 8000 0.0000 0 0 30 30 Y N
5 N 5.0000 8000 0.0000 0 0 0 0 Y N
Axis Kp Ki Kd Limit Kg Kv1 Ka Accel
X 1.000 0.00391 15.000 32000 0 12 13 0.3200
Y 1.000 0.00391 15.000 32000 0 18 10 0.3400
Z 1.000 0.00391 15.000 32000 2 15 21 0.6100
N 1.000 0.00391 15.000 32000 0 0 0 0.2000
Axis Motor Drive Drive Kp Ki Kd Feed Forward Encoder
Poles Curr. Angle Fixed /RPM cnts/rev
X 8 16 5 0.500 0.01250 1.000 0.2500 0.1000 8000
Y 8 16 5 0.500 0.01250 1.000 0.2500 0.1000 8000
Z 8 16 5 0.500 0.01250 1.000 0.2500 0.1000 8000
N 8 16 5 0.500 0.01250 1.000 0.2500 0.1000 8000
N 6 16 0 0.500 0.01250 1.000 0.2500 0.1000 8000
CNC10 v. 2.30 job info file
Last job file: c:\cnc10\ncfiles\GEN 5 STEP 1.cnc
Part count: 1 Edge Finder Diameter: 0.0000
PID Collection Axis: 1 Density: 1 Extension: DAT
Move Commands: 1
2
3
4
5
WCS: #1 X axis Y axis Z axis B axis N axis
G52 Shift Distance: 0.0000 0.0000 0.0000 0.0000 0.0000
Home State: Not set Not set Not set Not set Not set
Tool Reference: Not set Not set -1.4312 Not set Not set
Digitize Grid Radial Grid Radial
Filename: 287splug oneinmst Multi Patch: No
Replay Feedrate: 100.0000 20.0000 Pattern: Zig Zag CCW
Envelope: X 3.9000 S 0.00 Step: X 0.0150 0.2500
Y 2.0000 E 360.00 Y 0.0150
R 0.6000
Z Depth: 0.4000 -0.5000 Z Step: 0.0100 0.1000
Grid First Axis: 0 Radial containment: Full Clearance Ht: 0.0100
No Job Progress Recorded. Program Stack Level (PSL) = -1
Perform 'Forced' Tool Change: No
Tool in spindle: 24
ATC Error code: 0
Saved user variable values:
#150 = 0.0000
#151 = 0.0000
#152 = 0.0000
#153 = 0.0000
#154 = 0.0000
#155 = 0.0000
#156 = 0.0000
#157 = 0.0000
#158 = 0.0000
#159 = 0.0000
CNC10 v. 2.30 parameters file
00 0.0000| 20 72.0000| 40 0.0001| 60 0.0000| 80 0.0000
01 0.0000| 21 0.0200| 41 0.2500| 61 0.5000| 81 -1.0000
02 0.0000| 22 0.0200| 42 0.0000| 62 115.0000| 82 900.0000
03 0.0000| 23 0.0200| 43 1.0000| 63 128.0000| 83 0.0600
04 1.0000| 24 0.0200| 44 14.0000| 64 0.0000| 84 3.0000
05 0.0000| 25 0.6800| 45 0.0000| 65 0.1120| 85 1.0000
06 0.0000| 26 0.6800| 46 0.0100| 66 1.0000| 86 0.0000
07 0.0000| 27 0.6800| 47 1.0000| 67 1.0000| 87 36.0000
08 2.0000| 28 0.6800| 48 0.1000| 68 640.0000| 88 36.0000
09 0.0000| 29 150.0000| 49 0.0000| 69 1.7500| 89 36.0000
10 0.0000| 30 180.0000| 50 1.0000| 70 0.0010| 90 36.0000
11 14.0000| 31 -1.0000| 51 0.0000| 71 2.0000| 91 0.0000
12 10.0000| 32 19200.0000| 52 0.0010| 72 0.0000| 92 0.0000
13 0.0500| 33 1.0000| 53 0.0000| 73 0.0600| 93 0.0000
14 50.0000| 34 4096.0000| 54 0.0000| 74 4.0000| 94 2.0000
15 5.0000| 35 5.0000| 55 0.0000| 75 0.0000| 95 2.0000
16 10.0000| 36 0.0000| 56 0.0000| 76 0.0000| 96 2.0000
17 0.0000| 37 10.0000| 57 0.0000| 77 0.0000| 97 2.0000
18 15.0000| 38 0.0000| 58 0.0000| 78 0.0000| 98 45.0000
19 2.0000| 39 200.0000| 59 0.0000| 79 49.0000| 99 6.0000
100 1.0000| 120 0.1000| 140 3.0000| 160 0.0000| 180 0.0000
101 0.5000| 121 0.0020| 141 1000.0000| 161 0.0000| 181 19.2000
102 1.0000| 122 0.0002| 142 1000.0000| 162 0.0000| 182 801.0000
103 75.0000| 123 0.0000| 143 11.0000| 163 0.0000| 183 0.0000
104 0.0000| 124 0.0000| 144 9.0000| 164 0.0000| 184 10.0000
105 0.0000| 125 0.0000| 145 0.0000| 165 0.0000| 185 0.0000
106 1.0000| 126 0.0000| 146 0.0000| 166 0.0000| 186 0.0000
107 0.0100| 127 0.0000| 147 10.0000| 167 0.0000| 187 0.0000
108 0.0000| 128 0.0000| 148 0.0000| 168 0.0000| 188 0.0000
109 0.0000| 129 0.0000| 149 1.0000| 169 0.0000| 189 0.0000
110 0.0000| 130 0.0000| 150 1.0000| 170 0.0000| 190 0.0000
111 0.0000| 131 0.0000| 151 0.0000| 171 0.0000| 191 0.0000
112 0.0000| 132 0.0200| 152 48.0000| 172 0.0000| 192 0.0000
113 0.0000| 133 0.0000| 153 0.0000| 173 0.0000| 193 0.0000
114 0.0000| 134 0.0000| 154 0.0000| 174 0.0000| 194 0.0000
115 0.0000| 135 0.0000| 155 0.0000| 175 0.0000| 195 0.0000
116 0.0000| 136 0.6800| 156 2.0000| 176 0.0000| 196 0.0000
117 0.0000| 137 0.0000| 157 0.0000| 177 0.0000| 197 20930.0000
118 0.0000| 138 0.0000| 158 0.0000| 178 0.0000| 198 0.0000
119 0.0000| 139 0.0000| 159 0.0000| 179 0.0000| 199 0.0000
300 49040.2470 | 200 43952.5744 | 201 50608.0061 | 202 0.0000
203 0.0000 | 204 48560.7480 | 205 0.0000 | 206 35248.5198
207 63920.8694 | 208 42672.9354 | 209 52912.5929 | 400 0.0000
401 0.0000 | 210 40624.6772 | 211 0.0000 | 500 0.0000
510 0.0000 | 212 0.0000 | 213 0.0000 | 214 33968.2456
215 0.0000 | 216 59933.3962 | 217 0.0000 | 218 0.0000
219 0.0000 | 220 0.0000 | 221 0.0000 | 297 20929.6176
298 44304.9102 | 299 739134.0000 | 296 0.0000 | 295 122004.0412
CNC10 v. 2.30 coordinates file
Axis Minus Plus Return Return Return Return
Limit Limit #1(G28) #2(G30) #3 #4
X 0.0000 17.2500 0.00000 11.50000 0.00000 0.00000
Y -11.0000 0.0000 0.00000 -9.00000 0.00000 0.00000
Z -4.7250 0.0000 0.00000 0.00000 0.00000 0.00000
B 0.0000 0.0000 0.00000 0.00000 0.00000 0.00000
N 0.0000 0.0000 0.00000 0.00000 0.00000 0.00000
Axis Origin Origin Origin Origin Origin Origin
#1(G54) #2(G55) #3(G56) #4(G57) #5(G58) #6(G59)
X 8.46526 10.47104 0.00000 11.28333 9.57272 0.00000
Y -7.13007 -4.29818 -4.29745 -5.12977 -10.08698 0.00000
Z -2.70967 -1.79715 -4.04427 -1.07668 -1.89325 0.00000
B 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
N 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
CSR 0.000000 0.000000 0.000000 0.000000 0.000000 0.000000
#7 #8 #9 #10 #11 #12
X 0.38140 0.00000 0.00000 0.00000 0.00000 0.00000
Y -9.47740 0.00000 0.00000 0.00000 0.00000 0.00000
Z -3.09310 0.00000 0.00000 0.00000 0.00000 0.00000
#13 #14 #15 #16 #17 #18
X 0.00000 0.00000 0.00000 0.00000 0.00000 2.88670
Y 0.00000 0.00000 0.00000 0.00000 0.00000 -7.81280
Z 0.00000 0.00000 0.00000 0.00000 0.00000 -0.57320
Work Envelope
Axis - +
X 2.5000 17.2500
Y -11.0000 0.0000
Z -3.0000 0.0000
B 0.0000 0.0000
N 0.0000 0.0000
Modules Loaded:
nls_iso8859-1 2848 0 (autoclean)
nls_cp437 4352 0 (autoclean)
sd_mod 10448 0 (autoclean)
usb-storage 28080 0
scsi_mod 51552 2 [sd_mod usb-storage]
Pci9050 16128 0
plc 29456 0
usb-uhci 21232 0 (unused)
usbcore 49376 1 [usb-storage usb-uhci]
vfat 8816 0
fat 29984 0 [vfat]
63 plc
1 psaux
134 apm_bios
PLC Executor Status:
PLC program size : 2588
PLC program 32-bit checksum : 90000d27
PLC program run state : Run
PLC interrupt state : On
Interrupts serviced : 29574
Interrupts missed : 0
Missed interrupt timer : On
RTC frequency : 1024
RTC rate bits : 6
RTC Status Register : c0
PLC frequency : 256
PLC divisor : 4
Handwheel frequency : 1024
Handwheel divisor : 1
File system stats:
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/root 121075 94137 25688 79% /
/cncroot/c/cnc10 listing
total 2076
-rwxr-xr-x 1 root root 1227 Dec 11 2023 2131osgr.cnc
-rw-r--r-- 1 root root 457 Jan 23 2007 autotune.out
-rw-r--r-- 1 root root 160 Mar 14 2005 BACKLASH_TEST
drwxr-xr-x 2 root root 1024 Jan 24 2007 bin
drwxr-xr-x 2 root root 3072 Jan 24 2007 bmps
-rw-r--r-- 1 root root 45 Sep 5 09:51 checksum.out
-rw-r--r-- 1 root root 64 Aug 27 10:21 cnc10cam.sh
-rw-r--r-- 1 root root 162 Jan 24 2007 cnc10cams.txt
-rw-r--r-- 1 root root 46 Sep 5 09:51 cnc10.err
-rw-r--r-- 1 root root 115 Dec 23 2004 cnc10.m0
-rw-r--r-- 1 root root 115 Dec 23 2004 cnc10.m1
-rw-r--r-- 1 root root 180 Dec 23 2004 cnc10.m12
-rw------- 1 root root 4142 Aug 27 10:47 cnc10m.cfg
-rw-r--r-- 1 root root 48 Mar 11 2005 cnc10m.hom
-rw-r--r-- 1 root root 8935 Sep 5 09:51 cnc10m.job
-rw-r--r-- 1 root root 1640 Sep 5 07:27 cnc10m.ol
-rw------- 1 root root 1960 Sep 5 05:54 cnc10m.prm
-rw-r--r-- 1 root root 8080 Sep 4 10:41 cnc10m.tl
-rw------- 1 root root 3512 Aug 30 07:22 cnc10m.wcs
-rw------- 1 root root 1335 Dec 23 2004 cnc10.plc
-rw------- 1 root root 172 Sep 5 08:49 cnc10.tem
-rw-r--r-- 1 root root 40 Dec 23 2004 cnc10xmsg.txt
-rw-r--r-- 1 root root 128052 Aug 4 2006 cnc7.hex
-rw-r--r-- 1 root root 141686 Aug 4 2006 cnc8.hex
-rw-r--r-- 1 root root 10556 Jun 10 2020 dmesg.txt
drwxr-xr-x 2 root root 1024 Jan 24 2007 doc
-rw-r--r-- 1 root root 5180 Jul 24 2009 drag_x.out
-rw-r--r-- 1 root root 5180 Jul 24 2009 drag_x.tmp
-rw-r--r-- 1 root root 1941 Mar 11 2005 drag_y.out
-rw-r--r-- 1 root root 269 Mar 2 2009 drag_y.tmp
-rw-r--r-- 1 root root 1237 Mar 11 2005 drag_z.out
-rw-r--r-- 1 root root 1237 Mar 11 2005 drag_z.tmp
-rw-r--r-- 1 root root 51 Mar 29 2005 face
-rwxr-xr-x 1 root root 2700 Sep 3 09:08 GEN5STEP1_1.cnc
-rwxr-xr-x 1 root root 1615 Jan 24 2007 install.sh
-rw-r--r-- 1 root root 526214 Aug 4 2006 language.msg
-rw-r--r-- 1 root root 6 Jul 24 2009 locations.load.filter.default
-rw-r--r-- 1 root root 23 Jul 24 2009 locations.load.filter.history
-rw-r--r-- 1 root root 21 Aug 4 2006 locations.load.filter.static
-rw-r--r-- 1 root root 320 Sep 5 08:37 locations.load.recent.history
-rw-r--r-- 1 root root 3 Aug 8 2005 locations.transfer.destination.default
-rw-r--r-- 1 root root 68 Sep 5 09:51 locations.transfer.destination.history
-rw-r--r-- 1 root root 3 Jan 22 2007 locations.transfer.source.default
-rw-r--r-- 1 root root 27 Jun 12 2007 locations.transfer.source.history
-rw-r--r-- 1 root root 3 Jan 24 2007 locations.update.source.default
-rw-r--r-- 1 root root 6 Jan 24 2007 locations.update.source.history
-rw-r--r-- 1 root root 17464 Dec 23 2004 m400dc3c.src
-rw-r--r-- 1 root root 30535 Dec 23 2004 m400dc3p.src
-rw-r--r-- 1 root root 2217 May 2 2007 mathhelp.dat
-rw-r--r-- 1 root root 153 Mar 14 2005 M_BACKLASH_TEST
drwxr-xr-x 2 root root 1024 Jan 24 2007 md5
-rw-r--r-- 1 root root 162 Aug 16 2005 msflash
-rw-r--r-- 1 root root 70 Mar 11 2005 MSF_x0y0z0.test
-rw-r--r-- 1 root root 408 Sep 5 08:39 msg_cnt.err
-rw-r--r-- 1 root root 2041 Sep 5 09:51 msg_cnt.txt
-rw-r--r-- 1 root root 118906 Sep 5 09:51 msg_log.txt
-rwxr-xr-x 1 root root 804671 Jan 24 2007 mwbeta.zip
drwxr-xr-x 2 root root 5120 Sep 5 08:39 ncfiles
-rw-r--r-- 1 root root 1366 Mar 11 2005 O9101.cnc
-rw-r--r-- 1 root root 11255 Mar 11 2005 O9102.cnc
-rw-r--r-- 1 root root 2976 Mar 11 2005 O9201.cnc
-rw-r--r-- 1 root root 746 Mar 11 2005 O9202.cnc
-rw-r--r-- 1 root root 3695 Mar 11 2005 O9203.cnc
-rw-r--r-- 1 root root 475 Mar 11 2005 O9204.cnc
-rw-r--r-- 1 root root 913 Mar 11 2005 O9301.cnc
-rw-r--r-- 1 root root 118 Sep 5 09:51 pathm.ini
-rw------- 1 root root 3632 Dec 23 2004 pc.plc
-rw-r--r-- 1 root root 31902 Aug 4 2006 plc.o
-rw-r--r-- 1 root root 48165 Jun 10 2020 plcstate.txt
-rw-r--r-- 1 root root 3518 Dec 23 2004 plc.sym
-rw------- 1 root root 22 Dec 23 2004 readme.plc
-rw-r--r-- 1 root root 12207 Sep 5 09:51 report.txt
-rw-r--r-- 1 root root 51366 Jun 10 2020 report.zip
-rw-r--r-- 1 root root 27731 Aug 4 2006 systest.cnc
-rw-r--r-- 1 root root 7773 Mar 11 2005 systest.out
-rw-r--r-- 1 root root 4657 Dec 23 2004 xplc.sym
./bin:
total 5539
-rwxr-xr-x 1 root root 750 Aug 4 2006 addmouse.sh
-rwxr-xr-x 1 root root 542 Aug 4 2006 backup.sh
-rwxr-xr-x 1 root root 1143 Aug 4 2006 changeres.sh
-rwxr-xr-x 1 root root 992 Aug 4 2006 check_share.sh
-rwxr-xr-x 1 root root 866 Aug 4 2006 checksum.sh
-rwxr-xr-x 1 root root 714 Aug 4 2006 chelp
-rwxr-xr-x 1 root root 267064 Aug 4 2006 cnc10conv
-rwxr-xr-x 1 root root 2610696 Aug 4 2006 cnc10m.exe
-rwxr-xr-x 1 root root 812460 Aug 4 2006 cncedit
-rwxr-xr-x 1 root root 61716 Aug 4 2006 debug
-rwxr-xr-x 1 root root 341 Aug 4 2006 edit.sh
-rwxr-xr-x 1 root root 424 Aug 4 2006 format.sh
-rwxr-xr-x 1 root root 31708 Aug 4 2006 md5sum
-rwxr-xr-x 1 root root 1038 Aug 4 2006 nedit.sh
-rwxr-xr-x 1 root root 343 Aug 4 2006 netgo.sh
-rwxr-xr-x 1 root root 108060 Aug 4 2006 plccomp
-rwxr-xr-x 1 root root 713 Aug 4 2006 removemouse.sh
-rwxr-xr-x 1 root root 677 Aug 4 2006 report_copy.sh
-rwxr-xr-x 1 root root 667 Aug 4 2006 report_install.sh
-rwxr-xr-x 1 root root 2139 Aug 4 2006 report.sh
-rwxr-xr-x 1 root root 418 Aug 4 2006 restore.sh
-rwxr-xr-x 1 root root 2743 Aug 4 2006 runcnc.sh
-rwxr-xr-x 1 root root 562516 Aug 4 2006 showmsg
-rwxr-xr-x 1 root root 735 Aug 4 2006 startcnc10.sh
-rwxr-xr-x 1 root root 675588 Aug 4 2006 startmenu
-rwxr-xr-x 1 root root 482596 Aug 4 2006 xplccomp
./bmps:
total 4594
./doc:
total 25
-rw-r--r-- 1 root root 202 Aug 4 2006 7to10
-rw-r--r-- 1 root root 375 Aug 4 2006 cd
-rw-r--r-- 1 root root 774 Aug 4 2006 chattr
-rw-r--r-- 1 root root 51 Aug 4 2006 cnc10m4
-rw-r--r-- 1 root root 52 Aug 4 2006 cnc10t4
-rw-r--r-- 1 root root 265 Aug 4 2006 cnc10update
-rw-r--r-- 1 root root 64 Aug 4 2006 cncedit
-rw-r--r-- 1 root root 946 Aug 4 2006 cp
-rw-r--r-- 1 root root 244 Aug 4 2006 install-cnc10
-rw-r--r-- 1 root root 439 Aug 4 2006 install-config
-rw-r--r-- 1 root root 465 Aug 4 2006 less
-rw-r--r-- 1 root root 573 Aug 4 2006 ls
-rw-r--r-- 1 root root 1222 Aug 4 2006 main
-rw-r--r-- 1 root root 281 Aug 4 2006 mkdir
-rw-r--r-- 1 root root 132 Aug 4 2006 mouse
-rw-r--r-- 1 root root 756 Aug 4 2006 mv
-rw-r--r-- 1 root root 88 Aug 4 2006 netgo
-rw-r--r-- 1 root root 117 Aug 4 2006 pwd
-rw-r--r-- 1 root root 598 Aug 4 2006 rm
-rw-r--r-- 1 root root 353 Aug 4 2006 rmdir
-rw-r--r-- 1 root root 382 Aug 4 2006 screenresolution
-rw-r--r-- 1 root root 39 Aug 4 2006 statplc
-rw-r--r-- 1 root root 87 Aug 4 2006 tolwr
-rw-r--r-- 1 root root 96 Aug 4 2006 version
./md5:
total 4
-rw-r--r-- 1 root root 49 Aug 4 2006 cnc10m.md5
-rw-r--r-- 1 root root 43 Aug 4 2006 cnc7hex.md5
-rw-r--r-- 1 root root 43 Aug 4 2006 cnc8hex.md5
-rw-r--r-- 1 root root 43 Aug 4 2006 cnc9hex.md5
./ncfiles:
total 11273
-rw-r--r-- 1 root root 790 May 20 2005 116b037g.cnc
-rw-r--r-- 1 root root 1839 May 20 2005 116b041g.cnc
-rwxr-xr-x 1 root root 5646 May 20 2005 116b041g.icn
-rw-r--r-- 1 root root 2324 May 20 2005 116c018g.cnc
-rwxr-xr-x 1 root root 5233 May 20 2005 116c018g.icn
-rw------- 1 root root 261150 Aug 22 2007 ~121esc.dig
-rw-r--r-- 1 root root 261158 Jun 13 2007 121esc.dig
-rw-r--r-- 1 root root 23192 Mar 23 2007 121escfi.dig
-rw-r--r-- 1 root root 51804 Mar 26 2007 121escpr.dig
-rw-r--r-- 1 root root 2826 May 9 2007 134boltholeface.cnc
-rw-r--r-- 1 root root 966 Feb 6 2007 134Chev.cnc
-rw-r--r-- 1 root root 21 Apr 16 2009 134Chev.DOC
-rw-r--r-- 1 root root 3330 Mar 17 2009 134deck.cnc
-rw-r--r-- 1 root root 187589 May 1 2007 134eck.dig
-rw-r--r-- 1 root root 36465 May 8 2007 134hbh2
-rw-r--r-- 1 root root 36447 May 9 2007 134hbh.dig
-rw-r--r-- 1 root root 12298 Jun 11 2007 134sc.dig
-rw-r--r-- 1 root root 43731 Jun 28 2007 134seamcrack
-rw-r--r-- 1 root root 13886 May 3 2007 134seamcrack.cnc
-rw-r--r-- 1 root root 1282 Jun 11 2007 134seatc.dig
-rw-r--r-- 1 root root 440 Apr 16 2009 134seatc.DOC
-rw-r--r-- 1 root root 37734 May 31 2007 144cent13
-rw-r--r-- 1 root root 37736 May 31 2007 144cent24
-rw-r--r-- 1 root root 270222 Jun 7 2007 144toy13.dig
-rw-r--r-- 1 root root 510183 Mar 7 2007 144toy24.dig
-rw-r--r-- 1 root root 164453 May 2 2007 144wj.dig
-rw-r--r-- 1 root root 150 Aug 4 2006 1540050
-rwxr-xr-x 1 root root 1225 Dec 11 2023 2131osgr.cnc
-rwxr-xr-x 1 root root 1253 Dec 7 2023 2131osgr.icn
-rw-r--r-- 1 root root 1727 Aug 15 2023 2131testmahine.cnc
-rw-r--r-- 1 root root 257937 Apr 12 2007 287cham.dig
-rw-r--r-- 1 root root 313782 Apr 16 2009 287cham.DOC
-rw-r--r-- 1 root root 14767 Apr 30 2007 287deckcrack.cnc
-rw-r--r-- 1 root root 257373 Jul 24 2009 287fini.dig
-rw-r--r-- 1 root root 139913 Sep 2 2007 287half.dig
-rw-r--r-- 1 root root 799 Aug 3 2009 287sparkpulg.cnc
-rw-r--r-- 1 root root 555065 Aug 3 2009 287splug.dig
-rw-r--r-- 1 root root 14818 Apr 30 2007 287waterjaket.cnc
-rw-r--r-- 1 root root 9568 Dec 28 2022 2v_ptest_1.cnc
-rw-r--r-- 1 root root 3274 Dec 19 2022 2VP_TEST#1.cnc
-rw-r--r-- 1 root root 5418 Dec 28 2022 2v_ptest_2.cnc
-rw-r--r-- 1 root root 15160 Nov 30 2022 3059_3099_3154_bridge_mod.cnc
-rw-r--r-- 1 root root 2538 Mar 23 2022 36_SIM
-rw-r--r-- 1 root root 705 Aug 4 2006 5axis.cnc
-rw-r--r-- 1 root root 2030 Jul 13 2023 adaptercircle.cnc
-rwxr-xr-x 1 root root 1243 Nov 7 2023 AEP E GSKT CHMFR.cnc
-rwxr-xr-x 1 root root 1226 Nov 7 2023 AEP E GSKT REAM.cnc
-rw-r--r-- 1 root root 3317 Nov 7 2023 AFM_82_rev_5.cnc
-rw-r--r-- 1 root root 2880 Aug 14 08:09 AFM_82_rev_5copy.cnc
-rw-r--r-- 1 root root 1146 Nov 7 2023 AFM_82_rev_5.DOC
-rw-r--r-- 1 root root 3317 Dec 9 2022 AFM_90_rev5
-rw-r--r-- 1 root root 1145 Nov 7 2023 AFM_90_rev5.DOC
-rw-r--r-- 1 root root 4790 Jul 25 2023 AFMgen5cutout1.cnc
-rwxr-xr-x 1 root root 17938 Jul 25 2023 AFM Gen 5 Cutout 1.icn
-rw-r--r-- 1 root root 2106 Jul 26 2023 AFMgen5cutut2.cnc
-rw-r--r-- 1 root root 1926 Jun 8 2021 AFM-old2
-rw-r--r-- 1 root root 2917 Jun 10 2021 AFM_OLD.cnc
-rw-r--r-- 1 root root 3080 Jul 10 2020 AFM_OLD_DONT_USE
-rw-r--r-- 1 root root 1984 Jun 22 2021 afm_old_rev4
-rw-r--r-- 1 root root 1981 Jun 7 2022 AFM_REAMwCS_rev5.cnc
-rw-r--r-- 1 root root 2911 Aug 17 2020 Bad file
-rw-r--r-- 1 root root 15156 Mar 21 2022 Baffle Plate
-rw-r--r-- 1 root root 1927 May 11 2007 bolt.cnc
-rw-r--r-- 1 root root 1948 Mar 15 2005 BossCvr.cnc
-rw-r--r-- 1 root root 168770 Jul 13 2007 bowl.dig
-rw-r--r-- 1 root root 55634 Jun 1 2009 c134cyl.dig
-rw-r--r-- 1 root root 2521773 Aug 2 2007 C134fin.dig
-rwxr-xr-x 1 root root 8192 Sep 20 2005 CADglasc.dxf
-rwxr-xr-x 1 root root 29334 Sep 20 2005 CADglb.dxf
-rwxr-xr-x 1 root root 42137 Sep 20 2005 cadgl.dxf
-rwxr-xr-x 1 root root 0 Sep 20 2005 CADlg.dxf
-rwxr-xr-x 1 root root 46685 Sep 20 2005 CAD S151-LEFT-GUSSET-MOD.dwg
-rw-r--r-- 1 root root 1871 Jun 11 2021 CamPlate_Oversize.cnc
-rw-r--r-- 1 root root 19341 Jul 25 2009 ch287cyl.dig
-rw-r--r-- 1 root root 885 Jul 25 2009 ch287P2.cnc
-rw-r--r-- 1 root root 925 Jul 25 2009 ch287spr.cnc
-rw-r--r-- 1 root root 1146658 Jan 22 2007 cham1.dig
-rw-r--r-- 1 root root 233278 Mar 23 2007 CHAM2.dig
-rw-r--r-- 1 root root 27696 Feb 6 2007 cham2spk.dig
-rw-r--r-- 1 root root 2378 Jul 25 2023 circle.cnc
-rw-r--r-- 1 root root 2555 Feb 28 2009 cjtest.cam
-rw-r--r-- 1 root root 938 May 30 2007 clampbase.cnc
-rw-r--r-- 1 root root 2926 Aug 13 13:21 convgraf._nc
-rw-r--r-- 1 root root 1907 Jun 22 2021 counterbore_afms.cnc
-rw-r--r-- 1 root root 13761 Oct 27 2006 CutGrv1.cnc
-rw-r--r-- 1 root root 5522 Aug 4 2006 demo1.cnc
-rw-r--r-- 1 root root 15099 Aug 4 2006 demo3.cnc
-rwxr-xr-x 1 root root 6709 Sep 9 2005 din1.cnc
-rwxr-xr-x 1 root root 7847 Sep 9 2005 din2.cnc
-rwxr-xr-x 1 root root 3256 Sep 9 2005 din3.cnc
-rwxr-xr-x 1 root root 8927 Sep 9 2005 din4.cnc
-rwxr-xr-x 1 root root 30118 Sep 1 2005 dina.cnc
-rwxr-xr-x 1 root root 3548 Sep 8 2005 din.cnc
-rw-r--r-- 1 root root 3293 Feb 5 2007 DOM1.cnc
-rw-r--r-- 1 root root 739 Feb 10 2023 donotuse
-rw-r--r-- 1 root root 959 Aug 12 13:31 dp.cnc
-rw-r--r-- 1 root root 926 Jul 12 2023 drilladapter2.cnc
-rw-r--r-- 1 root root 2440 Jul 11 2023 drilladapter.cnc
-rw-r--r-- 1 root root 1180 Jun 25 2020 Drilling_4_Clamp.cnc
-rw-r--r-- 1 root root 1102 Jul 1 2020 Drilling_manifold_mounts.cnc
-rwxr-xr-x 1 root root 1852 Nov 7 2023 EARLY AFM GSKT MOD.cnc
-rwxr-xr-x 1 root root 3661 Nov 7 2023 EARLY AFM GSKT MOD.icn
-rw-r--r-- 1 root root 872 Jul 10 2023 EndSquare1.cnc
-rwxr-xr-x 1 root root 2986 Aug 30 2005 engrave.cnc
-rw-r--r-- 1 root root 662 Jan 13 2006 Faceoff.cnc
-rw-r--r-- 1 root root 3947 Mar 14 2005 flange.cnc
-rw-r--r-- 1 root root 23566 Aug 4 2006 flange.dxf
-rw-r--r-- 1 root root 1092 Jul 13 2023 Flycut1.cnc
-rw-r--r-- 1 root root 866 Jul 12 2023 Flycut2.cnc
-rw-r--r-- 1 root root 890 Jul 11 2023 Flycut3.cnc
-rw-r--r-- 1 root root 911 Jul 24 2023 Flycut4.cnc
-rw-r--r-- 1 root root 1239 Jul 24 2023 Flycut5.cnc
-rw-r--r-- 1 root root 959 Nov 10 2021 FORD_VLV_BREATHER.cnc
-rw-r--r-- 1 root root 2358 Jul 27 2023 gaugecutout.cnc
-rw-r--r-- 1 root root 1148 Dec 6 2005 GE129.cnc
-rwxr-xr-x 1 root root 3432 Sep 4 15:47 GEN4LATE_1.cnc
-rwxr-xr-x 1 root root 3432 Sep 4 15:47 GEN 4 LATE.cnc
-rw-r--r-- 1 root root 3341 Aug 14 10:09 GEN4LATE.cnc
-rwxr-xr-x 1 root root 2700 Sep 3 13:08 GEN5STEP1_1.cnc
-rwxr-xr-x 1 root root 2695 Sep 5 09:10 GEN 5 STEP 1.cnc
-rw-r--r-- 1 root root 2793 Aug 27 12:43 GEN5STEP1.cnc
-rwxr-xr-x 1 root root 2981 Sep 4 14:17 GEN5STEP2_1.cnc
-rwxr-xr-x 1 root root 2981 Sep 4 14:17 GEN 5 STEP 2.cnc
-rw-r--r-- 1 root root 2874 Aug 14 08:01 GEN5STEP2.cnc
-rw------- 1 root root 9502 Mar 6 2007 GroomsEnginesEngrave.NC
-rw-r--r-- 1 root root 160645 Jul 27 2009 hemicyl.dig
-rw-r--r-- 1 root root 1757 Jul 25 2009 HemicylP1.cnc
-rw-r--r-- 1 root root 1210 Jul 28 2009 HemicylP2.cnc
-rw-r--r-- 1 root root 1773356 Dec 5 2007 HEMI.dig
-rw-r--r-- 1 root root 1309 Jul 13 2021 hemi_LS_Tree.cnc
-rw-r--r-- 1 root root 107300 Mar 7 2007 intfl.cnc
-rw-r--r-- 1 root root 3271 Nov 7 2023 km_afm.cnc
-rw-r--r-- 1 root root 1351 Jul 19 2023 limitswitchls.cnc
-rw-r--r-- 1 root root 4328 Feb 10 2023 LSPANCCOLERonly
-rw-r--r-- 1 root root 5758 Feb 13 2023 LSPANCOOLEROnly.cnc
-rw-r--r-- 1 root root 1335 Feb 13 2023 lspanfiltermanual.cnc
-rw-r--r-- 1 root root 3714 Feb 13 2023 LSPANFILTERonly.cnc
-rw-r--r-- 1 root root 5623 Mar 22 2022 modify_sim_plate.cnc
-rw-r--r-- 1 root root 1477 Apr 5 2005 MSF_FACE.cnc
-rw-r--r-- 1 root root 2845 Aug 8 2005 msftut1b.cnc
-rw-r--r-- 1 root root 1769 Aug 8 2005 msftut1b.icn
-rw-r--r-- 1 root root 1274 Aug 8 2005 msftut1.cnc
-rw-r--r-- 1 root root 3344 Aug 8 2005 msftut1.icn
-rw-r--r-- 1 root root 4759 Aug 8 2005 msftut2.cnc
-rw-r--r-- 1 root root 3774 Aug 8 2005 msftut2.icn
-rwxr-xr-x 1 root root 804671 May 24 2006 mwbeta.zip
-rw-r--r-- 1 root root 39364 Nov 3 2006 nut_bore.dig
-rw-r--r-- 1 root root 264 Nov 3 2006 nut_cont.cam
-rw-r--r-- 1 root root 9325 Nov 3 2006 nut.dig
-rw-r--r-- 1 root root 1366 Mar 9 2009 O9101.cnc
-rw-r--r-- 1 root root 2976 Jul 8 10:29 O9201.cnc
-rw-r--r-- 1 root root 913 Nov 21 2007 O9301.cnc
-rw-r--r-- 1 root root 1719 Jul 8 10:29 O9800.cnc
-rw-r--r-- 1 root root 2788 Apr 9 12:30 oneinmst.dig
-rw-r--r-- 1 root root 1625 Apr 9 12:32 oneinmst.DOC
-rw-r--r-- 1 root root 954 Jun 25 2020 Ream_Fixture.cnc
-rw-r--r-- 1 root root 1078 Jul 1 2020 Reaming_manifold_mounts.cnc
-rw-r--r-- 1 root root 1724 Sep 21 2005 rglm.cnc
-rw-r--r-- 1 root root 718 Sep 1 2005 s151A.cnc
-rw-r--r-- 1 root root 2045 Aug 30 2005 shdrbrk1.cnc
-rw-r--r-- 1 root root 2322 Aug 30 2005 shdrbrk1.icn
-rw-r--r-- 1 root root 2063 Aug 31 2005 shhsface.cnc
-rw-r--r-- 1 root root 19479 Oct 9 2005 shtsfac.cnc
-rw-r--r-- 1 root root 7967 Jul 12 2023 sLOTTEST.cnc
-rw-r--r-- 1 root root 26070 Aug 29 2005 SMdmtbrt.cnc
-rw-r--r-- 1 root root 1649 Aug 29 2005 SMdmtbrt.icn
-rw-r--r-- 1 root root 1179 Jul 24 2009 startup.cnc
-rw-r--r-- 1 root root 2269 Jul 12 2023 surface_afm_tester_5.cnc
-rw-r--r-- 1 root root 6932 Mar 28 2007 T144hog.dig
-rw-r--r-- 1 root root 2573 Aug 7 2023 tchinslot.cnc
-rw-r--r-- 1 root root 773 Aug 4 2006 tchkdemo.cnc
-rw-r--r-- 1 root root 4036 Mar 28 2006 tdtd.cnc
-rw-r--r-- 1 root root 971 Jun 25 2020 TEST1.cnc
-rw-r--r-- 1 root root 10167 Jun 1 2009 test2.dig
-rw-r--r-- 1 root root 13518 Aug 4 2006 test3b.cnc
-rw-r--r-- 1 root root 5892 Aug 4 2006 test3c.cnc
-rw-r--r-- 1 root root 46564 Aug 4 2006 test3e.cnc
-rw-r--r-- 1 root root 6969 Aug 4 2006 test4b.cnc
-rw-r--r-- 1 root root 50087 Aug 4 2006 test4e.cnc
-rw-r--r-- 1 root root 863 Jul 25 2009 test.cnc
-rw-r--r-- 1 root root 898 Jul 5 2023 testfkyy.cnc
-rw-r--r-- 1 root root 1944 Jun 26 2023 testpocket.cnc
-rw-r--r-- 1 root root 1556 Mar 21 2005 Tnut.cnc
-rw-r--r-- 1 root root 1634 Aug 4 2006 toolcht1.cnc
-rw-r--r-- 1 root root 1000 Sep 23 2005 toppltb.cnc
-rw-r--r-- 1 root root 1381 Mar 22 2022 Triton_SIM
-rw-r--r-- 1 root root 2066 May 5 2005 tst1.cnc
-rw-r--r-- 1 root root 1018 Mar 29 2005 tst.cnc
-rw-r--r-- 1 root root 1697 Feb 5 2007 tstdem.cnc
-rw-r--r-- 1 root root 720 Feb 21 2006 tstdwmk.cnc
-rw-r--r-- 1 root root 838 Aug 23 2005 tstre.cnc
-rw-r--r-- 1 root root 803 Aug 23 2005 tstre.icn
-rw-r--r-- 1 root root 646 Jan 16 2007 tstwrm.cnc
-rw-r--r-- 1 root root 697 Jul 24 2009 tstwrmup.cnc
-rw-r--r-- 1 root root 935 Aug 4 2006 tt1loc.cnc
-rw-r--r-- 1 root root 8257 Feb 6 2007 tut2.cnc
-rw-r--r-- 1 root root 2057 Jul 21 2020 Valve_Compresser_Lock_2.cnc
-rw-r--r-- 1 root root 1027 Jul 21 2020 Valve_Compresser_Lock_3.cnc
-rw-r--r-- 1 root root 1009 Jul 21 2020 Valve_Compresser_Lock.cnc
-rw-r--r-- 1 root root 230 Mar 15 2005 vla.cnc
Updates installed...
--- Thu Sep 30 13:30:00 EDT 2004 ---
CNC Linux v1.15 update
Includes fonts and libs for CNC10 v1.15+
--- Thu Sep 30 13:30:55 EDT 2004 ---
CNC Linux v1.15 Chinese font update
Includes Chinese font for CNC10 v1.15+
--- Tue Mar 15 13:12:02 UTC 2005 ---
Archive: /cncroot/a///cnclinux120u1.zip
CNC Linux 1.20 Update Disk 1
Updates CNC Linux 1.15 to 1.20
Includes Hotplug Support for USB Storage Devices
--- Tue Mar 15 13:38:34 UTC 2005 ---
CNC10 Mill disk 1 installed.
--- Tue Mar 15 13:39:52 UTC 2005 ---
CNC10 Mill disk 2 installed.
CNC10 Mill v1.21
--- Wed Jan 24 10:52:13 UTC 2007 ---
Archive: /cncroot/a///cnclinux125.zip
CNC Linux 1.25 Update Disk 1
Updates CNC Linux 1.20 to 1.25
-Minor fix for mounting Windows network shares on systems with multiple hard drive partitions.
-Added missing library so mke2fs works.
-Added command wc to fix command not found error in usb.rc.
--- Wed Jan 24 10:57:04 UTC 2007 ---
Archive: /cncroot/a//cnclinux2271.zip
CNC Linux 2.270 Update Disk 1
Updates CNC Linux 1.25 to 2.271
- Fixes some problems with USB floppy disks not being accessible.
- Fixes some problems with removeable media not updating at the command prompt.
- New linux version numbering scheme to reduce confusion between CNC10 and CNC Linux versions.
- Adds executable(s) and lib(s) to support nedit.
- Moves IDE CDROM support to /dev/hdc. IDE CDROM is accessible via /cncroot/cdrom
--- Wed Jan 24 10:59:42 UTC 2007 ---
Archive: /cncroot/b///mill-disk1.zip
CNC10 Mill 1.51 Update Disk 1
--- Wed Jan 24 10:59:43 UTC 2007 ---
Archive: /cncroot/b///mill-disk2.zip
CNC10 Mill 1.51 Update Disk 2
--- Wed Jan 24 10:59:48 UTC 2007 ---
Archive: /cncroot/b///mill-disk3.zip
CNC10 Mill 1.51 Update Disk 3
--- Wed Jan 24 11:02:50 UTC 2007 ---
Archive: /cncroot/b///cnclinux230.zip
CNC Linux 2.30 Update Disk 1
Updates CNC Linux 2.271 to 2.30
- Adds executables to better support networked drives.
--- Wed Jan 24 11:05:22 UTC 2007 ---
CNC10 Mill disk /cncroot/b//mill-disk1.zip installed.
--- Wed Jan 24 11:05:33 UTC 2007 ---
CNC10 Mill disk /cncroot/b//mill-disk2.zip installed.
--- Wed Jan 24 11:05:38 UTC 2007 ---
CNC10 Mill disk /cncroot/b//mill-disk3.zip installed.
Completed Update to CNC10 Mill v2.30
--------- MD5 Checksums ---------
a66e15e1482d4dd848569b22b5225d6a bin/addmouse.sh
427a8df2c6ee43e754459fd62d5744e3 bin/backup.sh
54eee3bcfc9bcd6d4430999a6088deb3 bin/changeres.sh
96b6946fa643248c8b99bf5c5c91010d bin/check_share.sh
a4ecf02ea304d51bffb483a0aae87ca2 bin/checksum.sh
15fbdf617fdffa138bb02341f89954af bin/chelp
986b1e19f1fa7efd04e5c93c6225f219 bin/cnc10conv
c5438c83a176aa0ac835a8a5bb57910f bin/cnc10m.exe
e76a2a9e4ddc8ee15f27d1c3d79d1fbd bin/cncedit
3912609aba8a1d151d2fdf07e626aa1d bin/debug
42511119fcff2349ef4d9a4cd1aba9c6 bin/edit.sh
bcb94d43585ebd61a7015db69b113f10 bin/format.sh
5407bf0bd69bf1ee935af50a4a2673bd bin/md5sum
20bce8623bde3cd1bf60d1db72638466 bin/nedit.sh
70f82e0923febd6b71a9f266a9db4d79 bin/netgo.sh
91e8cd09905f963d0d37d33668c25ea3 bin/plccomp
68569a6ad4bc0eb46475cebc3d091716 bin/removemouse.sh
f016319e36f0ae233a35acd7505124bc bin/report_copy.sh
a1cc96d174549ca37bf5c2343f30407a bin/report_install.sh
164a9ae2b026b981b7073791603912f4 bin/report.sh
2622a1715ceb41d040c54d8121216032 bin/restore.sh
b99d38619d1b79ddb020cecbed7c0b58 bin/runcnc.sh
386e564a3fb5c5280c433276987dc9de bin/showmsg
42e3ddc43454708443338253eecc9506 bin/startcnc10.sh
da233a52b859e7c4c8a90b83ba694bbd bin/startmenu
9dcff190eeff84657ea4b8bc4f15789b bin/xplccomp
fe749b45eb70b5e29ab077693c4a1308 cnc7.hex
53d55f3ab26e3006ac27f5c7ceae5d60 cnc8.hex
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
C...467 is asking for the report.ZIP file which you need to upload. This contains the error log and many other useful items which are needed for full analysis
Hope this helps
Nigel
Nigelo - this is a much older Linux based CNC10 system that doesn't create a zip file like the newer versions.
It is version 2.30. It does create a report.zip. All CNC10/Linux versions do.
The user interface for specifying where to store a report is awkward, but there would have been a report.zip file in the same folder as the report.txt file.
Use the Alt-i PLC Diagnostic display.
On initial power-up, with the probe disconnected, what color are the dots for INP14 and INP15?
With the probe plugged in, what color are the dots for INP14 and INP15?
With the probe tripped, what color are the dots for INP14 and INP15?
With the probe unplugged again, what color are the dots for INP14 and INP15?
KEITH_TSE
Post by KEITH_TSE »
14: GREEN
15: GREEN
14: RED
15: GREEN
14: GREEN
15: GREEN
14: RED
15: RED
That is clearly a startup glitch, where the hardware/software does not correctly read the states of the inputs until there has been a change of state.
I do not immediately see anything in the CNC10 v2.3x release notes about it, but nonetheless you could try updating your software from v2.30 to v2.38.
You can download the CNC10 v2.38 Mill installer here:
http://www.cncsnw.com/238_mill_usb.zip
Unpack that ZIP onto a USB drive (but do not unpack the ZIP files contained within it); then use F7/Utility -> F2/Update.
KEITH_TSE
Post by KEITH_TSE »
Thanks a ton.
I will try to give it a shot this week as it is now in production use.
