system folder
system folder
With the ability to have the buttons directly run a file from the system folder it is more user friendly than going back to a skin event linked to a macro. The issue is that the system folder only has a few things in it when you save a report. I have been saving the system folder along with a report.
If the entire system folder contents could come along with a report it would be very helpful.
Ken
Re: system folder
yep! will do.Ken Rychlik wrote: ↑Fri Aug 16, 2024 5:09 pm With the ability to have the buttons directly run a file from the system folder it is more user friendly than going back to a skin event linked to a macro. The issue is that the system folder only has a few things in it when you save a report. I have been saving the system folder along with a report.
Re: system folder
Please don't include the entire contents of the system folder in every report.
That is as bad as including every last button from the VCP folder in every report, even though very few -- if any -- are custom for the current machine.
There are a large number of files in the system folder. The vast majority of them came with CNC12, and will not have been modified by the user.
Find a way to identify only those files which have been, or at least probably have been, modified by the user. Include only those files in a report.
- PLC Expert
Re: system folder
The xml macro line for VCP buttons can run a file from anywhere, not just the system folder.
system folder is intended for centroid stock macros for use with CNC12. They are not restored by the report as it may overwrite updated files installed with CNC12.
in addition, they are saved by the report will just not be restored automatically, can be found under the urf.zip in the report.
Centroid PLC Tutorial Videos
Re: system folder
Correct, I run button macros from a separate macro folder I created and include that folder in my custom backup script that grabs only the files I need for a fresh install that cannot use a report. Which is pretty much every install.Allin1Chris wrote: ↑Thu Aug 22, 2024 10:35 am The xml macro line for VCP buttons can run a file from anywhere, not just the system folder.
Re: system folder
Chris, can you give an example of a button script needed to run a macro from the macro area? Not a numbered macro, but one with a name.Allin1Chris wrote: ↑Thu Aug 22, 2024 10:35 am The xml macro line for VCP buttons can run a file from anywhere, not just the system folder.
If it would restore them with a report that way, that would solve my issue. I have looked in the system folder of a report and they are not being saved.
Ken
Re: system folder
there are two system folders in the report. the second one is in urf.zip file contained in the report.zipKen Rychlik wrote: ↑Thu Aug 22, 2024 4:02 pmChris, can you give an example of a button script needed to run a macro from the macro area? Not a numbered macro, but one with a name.Allin1Chris wrote: ↑Thu Aug 22, 2024 10:35 am The xml macro line for VCP buttons can run a file from anywhere, not just the system folder.
Re: system folder
[/quote]
[/quote]
There seems to always be some kind of programming surprise
[/quote]
Ken
Re: system folder
[/quote]
[/quote]
to be fair, chris did mention that in his post.
Re: system folder
Not really, it's been there all along Ken.Ken Rychlik wrote: ↑Fri Aug 23, 2024 9:42 am There seems to always be some kind of programming surprise![]()
