Acorn Plasma Questions
Moderators: cnckeith, Joey
BryanDowdy
CNC Control System Serial Number: 20D778803C24-1011237516
Post by BryanDowdy »
I've been running the Acorn Plasma for almost a year now. Over that time I've complied a list of questions:
1. Is it possible to have gcode load the correct Cut Profile? For example, in sheetcam when I use the 1/4" steel tool for the kerf offset. Could it also call for the 1/4" steel Cut Profile in Acorn when the gcode is loaded?
2. If above is not possible, would it be possible to have Acorn have have a pop up to remember you to check the Cut Profile before cutting? When we are cutting multiple different materials through the day, sometimes one of the guys forget to change the Cut Profile and we damage a cutting tip.
3. Can the virtual jog panel and acron screens be locked together? So when I switch the screen back from sheetcam both the VJP and acorn are selected?
4. Can it be enabled to jog the X and Y axis at the same time with the keyboard?
5. When loading a new cut file, some times the graph is blank or shows the previous part. The machine cuts correctly, just the graph display messes up.
I am running CNC12 v5.10
Album:
Centroid_Jacob
Web Developer
Re: Acorn Plasma Questions
Post by Centroid_Jacob »
I moved your post to the Plasma forum.
Joey
Plasma/Laser Lead
Post by Joey »
BryanDowdy wrote: Wed Aug 14, 2024 10:31 am I've been running the Acorn Plasma for almost a year now. Over that time I've complied a list of questions:
This is currently on the Future feature list
Ive created a Video on How this can be done. Check it out here
3. Can the virtual jog panel and acron screens be locked together? So when I switch the screen back from sheet cam both the VJP and acorn are selected?
When opening Acorn Plasma from the Windows task bar. Select the VCP first and then click the VCP to bring up CNC12
Diagonal Keyboard jogging will be available in the software release 5.2
Thank you for pointing this out. I will try to reproduce. IS there any situation when this can be reliably reproduced?
BryanDowdy
Thanks for the reply Joey. I will work on reproducing the graph error and getting back to you with more details
Album:
