Manual - Verify Probe Function message displays twice, and takes two cycle start presses. Also, previously reported, you can't use the Enter key to start this function when Enter key for cycle start is set in the wizard.
Laser - Setting position here with Set/F10 references the value that is set for the Edge Finder Diameter in the Manual screen. For example, if you have 0.375 set as the edge finder diameter, and you have a laser to spindle offset saved, it will subtract the radius of the edge finder from the final set position. It would also be nice to have the option to lock the X and Y together here, so when you hit "Set", it would do both at the same time if desired.
Probe Boss, Web, In/Out Corner - For each of these, you can't enter the values for Width, Diameter, or Clearance. Also, all probe cycles will start with the Enter key, but will not continue after the verify probe message with a second tap of the Enter key.
Plate - Personally, I'd like to have an option to return to G53 Z0 instead of a clearance height when finished. Perhaps a toggle for either way. Yes, I can edit the macro no problem, but...
