OAK lathe setup to use a tool touch off probe?
Posted: Thu Aug 01, 2024 6:36 pm
I would like to setup a tool touch off probe on my OAK controlled lathe. Is there a PDF document for this (typically wiring and parameters)?
I've seen the TT-4 probe offered for lathes (https://shopcentroidcnc.com/shop/cnc-pr ... touch-off/), but I've only found the documentation for setting it up on a mill.
My main question is what should the probe input be wired to and parameter 244 set to? Mechanical Probe Input 769 or AUX Probe Input 772?
Jim
Jim
