Page 1 of 2
Probe Arm for lathe
Posted: Mon Jul 29, 2024 1:38 pm
by suntravel
Since the automatic tool touch off works in all 4 directions, regardless if the TTO is in the spindle or off center, I designed a quick connect arm for the TTO.
This type of mounting the TTO will also allow to probe in +Z direction for left tooling, and if the workpiece is not too big you can probe with the workpiece in the chuck.
Re: Probe Arm for lathe
Posted: Sat Aug 17, 2024 12:09 pm
by suntravel
First part done....
Posted: Sun Aug 18, 2024 7:55 am
by suntravel
The Probe Arm is ready.
Now I have to make a square tip for the Probe.
Parts are milled with blue tape/CA mounting, threads are milled.
A big advantage of a probe arm is that you can measure tools with the workpiece clamped, or with a collet chuck, no need to change the collet for measuring.
I also was running out of X travel for big boring bars, now the probe can be mounted with X offset.
Posted: Thu Aug 22, 2024 4:23 pm
by suntravel
So now I got my solid carbide square for the TTO and just made the construction to mount it on the probe...
The square is a 3 buck replacement part for turning tool holders :lol:
If this works, easy peasy to measure lathe tools in all four (six) directions with high precision ;)
Posted: Fri Aug 23, 2024 3:15 am
by Black Forest
This is unacceptable work. Start over! :lol:
What is really unacceptable is you lately have only been doing inspiring work for the lathe.......us cnc mill only guys are feeling left out!
Posted: Sat Aug 24, 2024 8:28 am
by suntravel
This unacceptable useless thing for mill only owners is ready, but there is a solution :
Make a DIY CNC lathe, a mill is very handy for this purpose :lol:
Now easy peasy to measure cut off blades on the right side, and no need to calculate cut off thickness to the part...
Posted: Sun Sep 08, 2024 12:24 pm
by suntravel
Now a video with using the Probe Arm:
Posted: Tue Sep 10, 2024 5:44 am
by Black Forest
That is really a great addition to your lathe. I am always amazed at how your brain works. :shock:
Posted: Tue Sep 10, 2024 2:20 pm
by suntravel
Black Forest wrote: Tue Sep 10, 2024 5:44 am That is really a great addition to your lathe. I am always amazed at how your brain works. :shock:
No beer with CNC, but wine with CAM :D :D
Posted: Sun Dec 29, 2024 10:26 am
by suntravel
Update on the Probe Arm.
Craped the china probe and replaced with Centroid KP1
